Delta T14455-LHP Victorian Tub and Shower Faucet Trim Chrome T14455-LHP. Tub and Shower Faucets polished chrome. Victorian One Handle Shower and Bathtub Faucet Trim Monitor 14 Series. SOLD: LESS HANDLES, WITH METAL OR PORCELAIN LEVER. Single-function press Logo
A
Anonymous Posted on Aug 07, 2014
How do you determine which delta single lever shower is in your shower
denisentexas
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Aug 07, 2014
denisentexas
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
1553
Points
11
Http://www.deltafaucet.com/parts/id-my-product/index.html?reset=true#wiz you should be able to track down the one you have on this "troubleshoot your product
1 Related Answer
Anonymous
  • 176 Answers
  • Posted on Aug 28, 2011
SOURCE: i cannot loosen the interior
Try Hammer and chisil or punch
Why no water thru delta single lever kitchen faucet
can be a number of issues: clogged aerator, water supply is turned off, or supply lines are kinked, debris behind cartridge blocking flow, rubber seats out of place.... What has changed to cause problems?
1helpful
I installed a single lever b114900 fauset i turn the water on and the water come out of shower head and fauset
I woke up to this problem this morning and was told by delta it could either be the cartridge or the check valves assembly. For me it was the check valves. The plastic developed a small crack. Very simple process to replace the parts.
Can't regulate a delta shower.
If you have the type that you turn the handle like a clock, you have to find that perfect spot. It can be 3/4 of the way around. If you have the ball type, single lever, the rubber seats and springs under the ball should be replaced. Cost...less than $10 for the kit to do yourself.
We have two showers with Delta single lever faucets. Both have given us problems. Both allow little or NO hot water through the shower head. What can we do?
It sounds like there's a blockage in the valve. It needs to be removed to see if water is blocked and confirm you have hot flowing freely.
Leaky shower head
If you replaced the seats and springs and the problem continued you may need to get a whole rebuild kit including the ball and replace that one as well
Delta single lever faucet leakingafter bing shut off.
Will need to get delta faucet rebuild kit. Available at home depot, lowes or hardware store. It consists of valve stem seals & springs. The larger kit will contain ball assembly. Turn off water to faucet. Unscrew handle via set screw under plastic cap. Unthread cap over ball assembly. Pry out valve seals & springs. Reverse procedure to install.
3helpful
3answers
I recently move into a condo that has a Delta single lever Series 1400 single lever bathtub fixture. The bathtub has a shower nozzle that looks like it has been used. I cannot find where there is a button,...
Is there a button on the tub filler? How about the spout on the tub, does it lift up? If there is not a tub spout then it should be shower only, if it has a tub spout it has to have a lifter of some sort, the foto I found showed the little button lifter. Hope this helps.
How do you switch out the single lever dial on a delta shower fau
Hidden under the lever is a little hex screw. Use an appropriate hex a.k.a. "Allen" wrench to remove the handle. You might want to shut down the water service first to save your shower until later.
Water just trickles out
Some of the new units have stops installed on the valve itself. Make sure they are open.
Top Delta Home Experts
john h
Paul Carew
Paul Bade
Are you a Delta Home Expert? Answer questions, earn points and help others
