Here are some steps to tune a Teac LED/LCD digital TV without a remote:
Find the TV's on-screen menu buttons on the TV itself (often located on the side or bottom of the TV)
Use the arrow buttons to navigate to the channel setup or tuning menu
Select "Auto Tuning" or "Channel Scan" and follow the on-screen instructions to scan for available channels
If the TV has manual tuning option, select it and input the frequency, symbol rate, and other information for each channel you want to add manually.
Once the tuning process is complete, the TV should display all the available channels. If you are unable to access the menu without a remote, consider using a universal remote that is compatible with your TV or obtaining a replacement remote from the manufacturer.
you can program the channel manually, just press the menu button in the tv panel. select preset and then manual fine tuning to tuned every channel you want to watch and then save it.to make a manual fine tuning, press manual then select channel you want to tuned and then press vol. up/down button to search right frequency channel.do this process in every channel you want to tuned. hope this can help.
If there is a Menu button on the front panel of the TV you can surf thorugh its menu, and select auto tune function. If there is no such button, you must have its remote control to do this.
No you can't tune without the remote control except you can search on PCB board whether the additional/optional button for Auto Tuning or Manual Tuning. If it is exist you can add the button and use it. Other wise, there is no way to tune, and you have to looking for the remote controller..you can try to use the Universal remote first.
It you are probably pressing a button the tv itself that activates the remote finder so you can find the remote. this makes the remote beep. try pressing the button on the tv to cut it off.
If you are sure, that there's no way to do it manually on the TV, there are only two solutions: buy a new remote controlaccording to your TV set model (sometimes it's hard to find) or buy a universal remote control
I am afraid thatyou need the original remote to access tuning universal remotes will not give you this option. An original remote will probably be very expensive check with your local TV dealer.
SUPER8
