SOURCE: 2000 ford f250 super duty 4x4 7.3L diesel oil leak
The HPOP (high pressure oil pump) is right under the filter housing. There are 2 lines that distribute the oil to the cylinder heads. The o-rings on those fittings go out. Kit is available from Ford or International. You will need a special wrench to get to the fittings though.
SOURCE: diagnostic code meaning
P1247 means the Turbo Boost Pressure Low, this may be a turbo issue or a defective waste gate.
SOURCE: Where is the vehicle speen sensor located on a 99 ford f250
should be on the top of the trannie, some have them internall yin the Rear end, very few but some do
SOURCE: My horn does not work on my 2003 Ford f250 super duty PU truck.
The horn location is on the radiator support.
SOURCE: My ABS light comes on at times on my 2006 Ford F250 SD
you need to get the code in order to proceed. one of the tire sensors is most likely erratic. You wont know which one without a proper diagnosis.
