Question about Navman S50 3D Portable GPS Automobile Navigator Compact Case
I turn the sat nav on and all i get on the screen is a picture of a computer on a lead going to a sat nav but the charge only runs to the centre then runs back again, i only use the sat nav in the car, i have put it on reset but that does not work, what is the problem please.
Russ Hill
  • 4,057 Answers
The sat nav plug is connecting the data link prong so thinks its connected to a pc. try another power cable.
Posted on Jan 16, 2018
1 Related Answer
Anonymous
SOURCE: navman F10 wont function shows sat nav connecting to computer on screen
Try holding down on/off button till screen clears,switch back on and it should be working normally,this worked on mine,it had picture of laptop ,navman usb cable and a red cross,hope this helps.Cheers.
Posted on Jun 19, 2008
I have been told that I need to update the maps on my sat nav
Remove you sat nav from the car (I am presuming it is not factory fitted) attach to your computer via a USB cable there will probably be a USB mini or micro socket on the sat nav, you should have been supplied with the correct USB cable when you bought the unit.
Once you have connected your unit to the computer go to the sat nav manufacturer website and select products. Go to your product and look for downloads or updates.
Also check that the sat nav screen isn't asking you questions to communicate to your computer. Sometimes you have to agree that the unit an talk to the computer or nothing will happen.
When you have found the relevant update save it to your sat nav unit being carefully not to unplug the USB lead untill you are completely finished.
When you restart your sat nav it should be up to date.
Jan 04, 2017 | GPS
How to charge mio sat nav in car
should power up all the time
sales pitch doesn't mention a short life battery
can t find a user manual for that one
unplug it after a while if it wont function then it may not have a battery feature
Mio Spirit 685 5 Sat Nav with UK and Ireland Maps
Jul 19, 2016 | Mio Spirit 685 GPS 5" Widescreen Sat Nav...
I formatted my garmin sat nav which deleted everything off they sat nav how do i reload all new maps back on it. I downloaded all they new maps but can t get them to go on sat nav now
If you formatted it while it was attached to your computer, this means you've also deleted all the unit's software plus the maps. You'll need to send it in to Garmin to restore the original software, and there will probably be a service charge for this.
Sep 11, 2011 | GPS
Nuvi 250 will not turn on when charging.
There are two types of leads that you can buy.
The one supplied with the Garmin expects you to plug the GPS into the PC via the USB and if you use this to try and charge your Garmin in your car it will think it is connected to the PC and show the connection screen. it will charge the unit but you can't see the map.!!!
Make sure that you buy a lead specially for the Garmin for use in the car its the only type of SAT NAV that you will have this problem with.
LOL
Sep 12, 2009 | Garmin nuvi 250W GPS Receiver
NAV U53 GPS - MESSAGE 'SERVICE' ON A BLUE SCREEN AND A SPANNER
This is a return to Base requirement as there is no owner solution to this problem. This is the tricky garmin group doing a "Microsoft" to get more $$ from their users.
Perhaps consider an Altina,next time they have no sneaky money grabbing tricks to make money out of you at every turn. Garmin were good once but they have joined the throw away mantality group.
You can check out an altina at Marbella australia the main service centre and distributor
Jun 30, 2009 | Garmin nuvi 260W GPS Receiver
Ay to be sat nav
try charging battery hooked up to the computer
there also is a lock on the start button
slide halve way instead of all the way over
May 30, 2009 | Tomtom One XL GPS Receiver
Sat nav maps/gps not working on MIo 268+
Turn the device off( from the back button) press volume up and the flag button( third from the right) in the same time and power on the device. Keep pressed the two buttons untill a screen shows . Press ok and then another ok. Then restart the device. This will do it
Jan 07, 2009 | Mitac Mio 268 Car GPS Receiver
SAT NAV NOT COMMING ON
try putting needle in reset button underneath
Dec 23, 2008 | GPS
Navman F10 wont function shows sat nav connecting to computer on screen
Jun 10, 2008 | Navman F20 GPS Receiver
Navman S50 3D Portable GPS Automobile Navigator Compact Case Logo
89 people viewed this question
Top Navman GPS Experts
Marvin
Marvin
Sheldon Dedek
Are you a Navman GPS Expert? Answer questions, earn points and help others
