Question about HP Compaq Presario CQ57-229WM Notebook PC
How to replace the 601 battery - HP Compaq Presario CQ57-229WM Notebook PC
    Sergeant:
  • HP Expert
  • 464 Answers
  • If Primary (internal) Battery (601) appears in the alert message, it means the measured storage capacity of the primary (internal) battery is less than 25% of the original storage capacity. The number "601" denotes the associated error code that is recorded in the system log.
To resolve a Battery Alert message, you should perform the Battery Test in the System Diagnostics (F2) environment, and calibrate the battery for best performance.
To access the HP System Diagnostics Battery Test , turn on the computer and immediately press the esc key to display the Startup Menu. Press the System Diagnostics F2 key, and then select the Battery Test option.
if it shows bad health You might need a new battery.
Posted on Aug 12, 2014
How do you get to the internal battery on a G56 HP Laptop?
The error message refers to the battery on the bottom of the notebook that powers it when it's not connected to A/C power. If you go into the F2 at startup or use HP Support Assistant, you can run a comprehensive battery test
Mar 16, 2015 | HEWLETT-PACKARD HP G56-122US Notebook
Internal battery 601
Replacing the bios battery will fix that.
Jul 14, 2014 | Computers & Internet
What does the internal 601 Battery do, and how to replace it
Do you use your power off the mains at all (not plugged in) It will be the main battery for the laptop.
If you always leave your laptop plugged in there isn't much point in getting a new battery. Perhaps you can turn off the error message on startup?
Feb 27, 2014 | HP Pavilion dv7-1129wm Notebook
Battery 601
This is battery error. You should install HP assistant that will show you how much battery life is expected and condition(normal, excellent, changeable)
Nov 22, 2013 | HP Pavilion dv7-1129wm Notebook
I NEED THE CODE TO AN LG LCD TV FOR THE BRIGHTSTAR BR100Z
here is a list of tv codes hope this helps
Admiral 500, 614 , 902, 615, 610, 501
Advent 911, 932, 933
Aiko 900
Akai 601, 903, 922
AOC 601, 617, 103
Apex 000, 618, 604
Audiovox 100, 901, 900, 101
Belcor 617
Bell&Howell 620, 611
Bradford 901
Brockwood 617
Broksonic 902, 614
Candle 601, 619
Celebrity 605
Changhong 618
Citizen 903, 601, 619, 900
Clairtone 103
Concerto 619
Contec 901, 103
Craig 901
Crosley 303, 301
Crown 901
Curtis Mathes 400, 301, 620, 100, 500,
903, 621, 606, 619, 611,
603, 102, 402, 401, 405
CXC 901
Daewoo 100, 617, 900, 101
Daytron 617
Dumont 700, 617
Durabrand 902, 901, 201, 614, 615, 914, 918
Dynex 614
Electroband 605, 103
Emerson 620, 902, 614, 901, 200, 201
607, 617, 615, 602, 103, 101
Envision 601
ESA 901, 201, 601, 903
Fisher 620, 801
Fujitsu 615, 300
Funai 901, 615, 201
Futuretec 901
GE 400, 202, 100, 200, 607
608, 802, 402, 401, 405
Gibralter 700, 601, 617
GoldStar 601, 607, 617, 619
Grundy 901, 615
Haier 914, 918
Hallmark 607
Harvard 901
Hitachi 606, 619, 611, 005, 916
ILO 921, 925, 609
Infinity 301
Inteq 700
Insignia 614, 303, 201,301, 909, 919, 920, 934
JBL 301, 000, 604, 618
JCB 605
JC Penny 400, 609, 202, 903, 601, 607,
608, 617, 800, 402, 405
JVC 701
KEC 901
Kenwood 601, 617
KLH 618
KTV 901, 601, 103
Konka 904, 001, 304, 002, 003
LG 619, 910, 700
Logik 611
Luxman 619
LXI 400, 301, 620, 609, 607, 402
Magnavox 301,302, 303, 601, 615, 617, 803,
905, 906, 907, 908, 909
Majestic 611
Marantz 301, 601
Matsushita 004
Megatron 607, 606
MEI 103
Memorex 620, 004, 614, 104, 607, 615, 611
MGA 104, 601, 607, 617, 500
Midland 400, 700, 202, 402
Minutz 608
Mitsubishi 500, 104, 607, 617, 601
Motorola 500, 802
MTC 903, 601, 617, 619, 103
Multitech 901
NAD 609, 607, 603
NEC 601, 617, 619
Nikko 601, 607, 900
Noshi 800
NTC 900
Olevia 923
Onwa 901
Optimus 620, 004, 603
Optonica 500, 610
Orion 902, 614, 615
Panasonic 004, 202, 802, 610
Philco 301, 614, 601, 606, 617
Philips 301,302, 303, 601, 615, 617, 803,
Pilot 601, 617
Pioneer 603, 600
Polaroid 400, 910, 913, 915, 917, 920
Portland 617, 900
Prism 202
Proscan 400, 402
Proton 607, 102
Pulsar 700, 617
Quasar 004, 202, 610, 802
RadioShack 400, 620, 610, 901, 621
607, 617, 619, 402
Realistic 620, 610, 901, 601, 607, 617,619
RCA 400, 617, 800, 612, 600
402, 403, 401, 404, 405, 623
Rhapsody 103
Roomconx 614, 615, 902, 924
Runco 700, 601, 616
Sampo 601
Samsung 903, 601, 607, 617, 619, 930
Sansui 614, 902, 615
Sanyo 620, 801, 931
Scotch 607
Scott 902, 901, 607, 617, 615
Sears 400, 301, 620, 609, 607
615, 622, 801, 201, 402
Sharp 500, 610, 501, 929
Sharp (LCD) 912, 929
Shogun 617
Signature 611
Simpson 803
Sony 605
Soundesign 901, 607, 615
Squareview 201
SSS 901, 617
Starlite 901
Supreme 605
Sylvania 301, 601, 201, 901
Symphonic 901, 201
Tandy 500
Tatung 802
Technics 004, 202
Techwood 202, 619
Teknika 301, 901, 104, 605, 617
615, 619, 611, 900
TMK 607, 619, 602
Toshiba 620, 609, 903, 613
Trutech 101
Victor 701
Vidtech 607, 617
Vizio 927
Wards 301, 610, 601, 607, 608
617, 615, 619, 611
Westinghouse 926, 928
White Westinghouse 614, 101, 605
Yamaha 601, 617
Zenith 700, 614, 611, 900, 619
Feb 25, 2013 | Universal Remote Control Remote Control
601 error message
Hello.
I am sorry that you are experiencing this error message. It generally indicates that your measured storage capacity in your primary battery is less than 25%. What this means is that your primary battery (601 indicates that it's primary) can only keep a 25% charge. To keep this quite simple for you, please attempt the following.
* Unplug your power cord.
1.) Start up your Laptop and hit the ESC key immediately.
2.) Press F2 to get into Systems Diagnostics.
3.) Select Battery Test. * Now, plug in the power cord.
4.) Start Battery Test.
The battery test will give you a STATUS. If you see the following;
- Calibrate: This means that your battery is functioning correctly but it is in need of calibration. Select the automatic calibration option.
- Weak: From here, please get a new battery to ensure that your getting adequate power supply to your laptop for use.
- Replace: Replace the battery.
- No Battery: If there is, indeed, a battery inserted. Remove it, check for dust/dirt and wipe it clear. Insert the battery and see if it works now.
- Unknown: Try to download all available updates from HP Support Assistant.
Feb 09, 2013 | HP Pavilion ze2000 Notebook
601 internal battery error
Replace the battery. See utube for video instruction; type in your model and 'CMOS battery replacement', in the search box.
Jul 11, 2012 | HP EliteBook 6930p Notebook PC
Internal battery error 601 hp compaq 6735s laptop
Remove the main battery and run the ac adapter only, if everything works fine the battery will need to be replaced, if the computer continues to shutdown the problem is most likely a bad cooling fan or it needs to be taken apart and given a good cleaning.
Jun 16, 2012 | HP Compaq 6735s Notebook
Hp dv7-1245dx error 601
Go in to bios and reset to factory default.
Mar 26, 2012 | HP Pavilion dv7-1245dx Notebook
HP Compaq Presario CQ57-229WM Notebook PC Logo
585 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Toby Lee
Toby Lee
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
