Question about HP DeskJet 920c InkJet Printer
How to reset counter 920c ? - HP DeskJet 920c InkJet Printer
1helpful
Windows 7 64 bit. HP Deskjet 920c will not load from HP program disc.32 bit. HP site says it no longer supports HP 920c. How do I obtain a 64 bit driver?
Unfortunately, if HP has ended support for a printer, there will be no new or updated drivers created for that printer to work with new versions of Windows. This also applies to Apple computers as well.
You might want to visit this web site at HP.com for the 920c to follow the steps they list there: http://support.hp.com/us-en/product/hp-deskjet-920c-printer-series/28856/model/45443/document/c01796879/
As they mention, when a printer model is older, HP gives the driver code to Microsoft to embed in the Windows system, but that driver then is fixed in time and will get no more updates.
1helpful
How to reset the hp deskjet 920c
  1. Open Printers by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers.
  2. Right-click the printer you want to use, and then click Set as Default Printer. A check mark is displayed on the printer icon to mark it as your default printer.
gl_ico.png Tip
To add a shortcut to Printers on your Start menu, right-click the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, click Properties, and then, on the Start Menu tab, click Customize. Select the Printers check box, and then click OK.
920c is printing very slow, like 1 copy in 5
it is possible that your printer settings is set print high quality for a photo paper. try to check if you are printing on plain paper, select paper type as plain paper and quality to normal.
No toolbox for HP deskjet 920c on VISTA
there probably is no download you will probably have to buy a disc
Hp 920c
is printer driver installes if so go into control panel and check that the 920c is selected as active printer...
Communitcate/test sheet
You didn't mention installing the 920c on your computer. You should have received an HP Deskjet 920c series printer software CD which installs the printer on your computer. You may need to check the HP web site to see if your computer is equipped with the appropriate driver. The 920c is an older HP printer. One of my printers is a 920c and I had no problem installing it a computer with Windows XP.
Hp printer deskjet 920c
My HP deskjet 920c won,t stop blinking, eventhough I have changed the
color and black and white carthridge. It will not print.
Hp 920c
Do you have the print cartridge that you replace from this printer. Put it back in and see if you print you may have purchased a bad cartage
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
HP DeskJet 920c InkJet Printer Logo
Vinaya Kumar...
Vinaya Kumar...
Ekse
