Question about Whirlpool Dryers
How do I fix a squealy elct. dryer?
Squeal is intermittent, about every third load.
2 Suggested Answers
John Morganti
  • 864 Answers
SOURCE: My Maytaag dryer has a loud intermittent squeal.
I think the drum drive belt is slipping because it occurs more with a large load. Other possibilities are: A drum support wheel bearing could need lubrication or be replaced. Also some drum support wheels have a rubber coating that wears off causing misalignment and noise. Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced. See the following for info about dryer repair including belt replacement:http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Posted on Sep 21, 2009
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: Our front load fridgidare dryer has began to squeal
You need a rear bearing most likely (5303281153)
This kit includes all that you need to redo the drum bearing. I have repair photos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 08, 2010
Hi my 06 rodeo 4x4 dual cab diesel has been making an intermittent squeal from the offside rear since 5000 kms.
Is the squeal constant and alters with road speed or is it a pulsing pattern, (like a playing card on slow turning bike spokes)? If you do a lot of dirt road driving it would be worth checking the obvious stuff as well. Things like bent or damaged back plates on the brakes, dirt or debris trapped underneath. Depending on what the squeal sounds like, (metallic or deep tone), it could even be a tyre rubbing in the arch.
A constant sound could be a bearing or a flexible joint in a driveshaft, (UV or CV joint).
A pulsing pattern could be a warped brake disc or brake drum. After a longer run CAREFULLY touch each back wheel rim. A dragging brake generates more heat. (One wheel hotter than the other).
hope this helps.
Mar 11, 2018 | Cars & Trucks
Intermittent High pitch squeals
other than check your wiring for rubbed spots or loose connections, I don't know. maybe try swapping parts one at time with your buddy. maybe your headset?
Jul 09, 2010 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
Intermittent - sounds like a cat caught under the
From what you have described I believe what you have is intermittent belt squeal in the serpentine belt. These tend to squeal in cold and damp weather and usually the noise will typically dissipate once the belt warms up from friction and radiated engine heat. (This is not always the case however).
You should check the belt for age and wear and, if in doubt, replace it as these are quite inexpensive items which need periodic replacement in any event. Also make sure the current belt - and any replacement - is properly aligned on the pulleys.
If you have no record of when the belt was last changed I would replace it even if it looks ok. These are easy and quick for an experienced person to replace.
Often when you replace the serpentine belt the squeal will disappear but return again as the new belt "wears in".
There are some temporary fixes for noisy belts which sometimes work (such as removing it and lightly spraying the belt with "Belt Grip"). There are also 1 or 2 others but I would not recommend them.
Dec 06, 2009 | 1995 Jeep Grand Cherokee
My Maytaag dryer has a loud intermittent squeal. It will often work for 10-15 minutes with a quiet squieak or no noise, then the loud squeak starts up. I can turn the dryer off, but the squeal immidately...
Sep 21, 2009 | Dryers
Mercedes-benz 1979 300D warning light
hi,two possible answer ,check your brake pad thickens and your brake fluid lever,ty
Mar 25, 2009 | 2005 Mercedes-Benz Mercedes Benz E320 Cdi
Intermittent squeal Nissan Primera Y reg 1.8
That would be the Wheel Bearings or the Brakes. Check the Brake Pads first for Wear, If they are OK, Then you will need to Pull the Rotors and Replace the Bearings.
Jan 23, 2009 | 2005 Nissan Altima
Dryers Logo
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Ned Halaweh
Ned Halaweh
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
