It shows error 5020
SOURCE: How do I resolve Error U150 on Canon MP810?
have had a MP810 about 3 months. Recently I've been getting a U150
error message. My C tank is not lighting up and being recognised. When
I open up and replace the tank the light comes on. Initially this
allowed me to carry on printing but now I have a constant error message
even after replacing the tank.
Is there a permanent solution to this annoying problem?
I would be grateful for any assistance.
SOURCE: printer canon mp810 displaying 5020 error
Hi
This maybe a small bit of paper in the rollers somewhere you need to find it or it is need of a good clean.
You can also try this.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: my canon mp810 is giving
I will suggest you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see what happens. let me know if additional information is required.
SOURCE: mon imprimente pixma mp810 donne
This correction is listed on the Canon website.
Lock Switch
Make sure to unlock the scanning unit before turning the machine on.
Caution : Make sure to unlock the Scanning Unit (Printer Cover) before turning the machine on.Before transporting the machine, always lock the Scanning Unit (Printer Cover) by moving the Scanner Lock Switch towards the lock mark.
SOURCE: Whilst printing on my Canon
It means scanner locked
action:
Slide the lever to lock the scanner in the open position, turn off and turn MFP
