Actually it's not to hard to connect them. All you need is a stereo record where you know a sound of something is on the right or left channels. I use to have a Goodies LP where a one of them would say "bounce to the left" and the other said "bounce to the right" these coming on the respective channels.
To set it up just stick the red (right) on one of the cartridge pins and white - left on the opposite side - not underneath it. Then connect the other two to the pins below them. Play your test record. And if the sound which is supposed to be on the right channel come on the left - swap the two red and white wires around.
If the sound sounds (tinny spaced) out then swap the same side wires around.
So if you have say Red Green, Make it Green Red. If it is tinny only on one channel, don't switch the other channel around.
For example the right is tinny - do the above - but leave the other White Blue.
By the way some cartridges do have L and R marked on them and + and - for the channel types. " -" being for the green or blue wires.
Check all conections to the turntable, also I think you should buy a new cartridge as a matter of course. I rather suspect it's (the cartridge) either **** or gone!
This might be helpful. Most stereo receivers have 2 sets of speaker outputs, A and B. Each have outputs for left and right speakers. On the front panel of the receiver, there should be a switch to turn on/off speaker A/B. When using both A and B, (a set of speakers on each A and B) you will lose a bit of volume.
Another possibility is, if the speaker cable length to your covered porch is a long distance from the receiver, you will lose some power from the receiver. Try using a thicker gauge speaker cable for longer cable runs. Try 14 gauge or 16 gauge.
You would need an adapter made specifically do come from an LG headphone port to plug into a radio.
The reason being because the Scoop's port has more contact points than a standard stereo port because it also uses the microphone on the same wire. The adapter you have is not compatible if you are only hearing one audio channel (left - right).
You could start by adjusting the Treble and Bass. The treble is what makes the high notes more nodicable, so if you turn the Treble up you should be able to hear more vocals. The Bass is what makes the low notes more nodicable, so if you turn the bass down you should be able to stop the shaking which I'm guessing is the low notes. On the other hand if you have an aftermarket radio then there might be a Mute or ATT button. Theses are for instant quiet, just repress the Mute or ATT button and it should be fine. I hope I could help.
-Andrew Hawkins
