If your electric tea kettle is leaking water from the bottom, it is likely that the seal or gasket between the heating element and the kettle body is damaged or worn out. Here are some steps you can take to fix the issue:
- Unplug the kettle and let it cool down completely before attempting any repairs.
- Check the bottom of the kettle for any visible cracks, holes, or damage. If you find any, you may need to replace the entire kettle.
- If the bottom of the kettle looks fine, remove the base of the kettle by unscrewing the screws or pressing the release button (depending on the model). This will expose the heating element and the gasket.
- Inspect the gasket for any signs of wear or damage. If it looks worn or torn, you will need to replace it with a new gasket. You can find replacement gaskets at the manufacturer's website or an appliance parts store.
- Carefully remove the old gasket and clean any residue or debris from the gasket groove.
- Install the new gasket in the groove, making sure it is properly seated and not twisted or pinched.
- Reattach the base of the kettle and tighten the screws or press the release button to secure it in place.
- Test the kettle to ensure that it no longer leaks.
If you are uncomfortable attempting these repairs yourself, it is recommended to contact the manufacturer's customer service or a professional appliance repair technician to assist you.
