Kitchenaid quiet scrub
How do i remove the spinner
    New Friend:
    Problem Solver:
  • 12 Answers
I pulled a spinner out of a LG washer a month ago, it's a tuff job, lay the machine over on it's side, pull the back panel. you will just about take the machine completely apart. the water jacket and basket have to come out of the housing. I suggest that you mark all connectors, I usually take masking tape and put it across the two halves of the connection and label it 'a' or one, what ever makes you happy, then start disconnecting them one at a time checking if it has to come apart to relieve the barrel from frame. As you start taking bolts and springs apart it ends up being self teaching, but if you are not very well mechanically inclined, you will not be able to do this job. take pix of everything so it will be allot easier to put it back together again. Remember it's not Humpty Dumpty, and can be put back together again, I did and had never done it before, wallah. Questions,[email protected]
Posted on Aug 06, 2014
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Washing machine does not spin
Affinity will not spin??
Posted on Feb 15, 2009
Anonymous
SOURCE: Washing Machine doesn't spin.
kitchen aid "quiet scrub" won't pump out the water? perhaps replace the unit or fix it?
Posted on Mar 17, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Kitchenaid top loading quiet scrub washing machine wont drain
It appears your belt has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Broken Timer? My OLD Kitchen Aid Quiet Scrub Dishwasher no longer advances through cycles automatically--I have to turn the knob manually for every step. It works fine other than that.
Hi Spring
All depends where you are and wether you can get Parts.
Is the timer accessible?
Timer is driven by a small clock motor.
Could it be fixed or lubricated.
Give it a service and save money!
Good luck
Free Online KITCHENAID DISHWASHER Repair Manual
http://www.diytroubleshooting.com/kitchenaid-dishwasher-troubleshooting
Jul 08, 2015 | KitchenAid Dishwashers
How do I remove the plunger for washing?
The plunger on mine cannot be removed. I just checked it to make sure. If you remove it, you have broken the unit. Just rinse with water. The plunger should not get dirty of used properly. A rinse under running water is enough.
Jan 28, 2015 | KitchenAid Salad and Fruit Spinner - White...
Can't lock down my kitchen aid salad spinners handle
You can't the product sucks worst salad spinner on mkt.way over priced
Apr 08, 2014 | KitchenAid Green Apple Classic Salad...
I have a kitchenaid quiet scrub dishwasher that fails to function. When you close the door and press the start button the clean and cancel lights come on and the pump starts up. No water enters the...
ther is a small impulse pump on the bottom of the unit. the diaphram gets old and it stops functioning but sometime then it leaks . so if it's not leaking , turn off water suppl and remove the fitting for incoming water some have screens right here and they get plugged with hard water debris . ha dont be silly all water is dirty.you can get new screens at h/d and lowes, hope your solenoid still works, check it by putting a finger on it when the cycle should start it should humm or vibrate. diaphram is not replaceable. need to buy new valve
Sep 06, 2012 | KitchenAid Dishwashers
Top rack spinner is not spinning
First check - ensure that the jets at the end of the spinner blade are not blocked. Check that the spinner is not siezed by turning it by hand, other than a cracked or disconnected pipe, there can not really be another reason for the spinner not rotating (if the bottom one rotates).
Jan 15, 2011 | KitchenAid Dishwashers
Oct 01, 2009 | KitchenAid Washing Machines
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
