Question about Bulova Watch
Argos assembly instructions
How do you build it ?
Posted by amanda on
I just bought the adidas ADP6000 watch from argos and the manual is no help at all and i cannot work out how to change the time and date even though i have researched online :(
Okay so I had the same problem as all you guys, fiddled around with the buttons for a couple seconds (literally) and worked it out
The following instructions are for tADP6000:
1- press and hold 'SET/LIGHT' button
2- it should say 'LIGHT' and 'OFF' flashing, now press 'MODE' until you reach the screen you desire, then use the 'START/STOP' and 'LAP/RESET' to change between 12hr/24hr; time; date etc etc. hope this helps
Jun 13, 2011 | Adidas Digi III Watch
Timex compass properly not working
First, assuming you do not have the manual, following the notes below, find an outdoors location away from any medal building, obstructions, etc. You must calibrate the compass to get anywhere near the +/- 10 degrees accuracy readings claimed.
Timex has two ways to find information about your particular watch. If you don't have the manual, Try this link:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
Sep 08, 2010 | Watches
Can i find instuctions to compass watch
Sep 07, 2010 | Timex Expedition E Compass Watch Titanium...
Just replaced battery in RSS210...now ony the set button works
How old is the watch? The buttons could have a build up of dirt around the buttons and that will keep them from working! If thats the case you can take a pin or a very thin screwdriver and run it around the botton to unclog the build up...or you can also take it to a reputable watch repair shop and they can disassemble the watch and remove the buttons and clean it really well.
Its also possible that the watch wasnt assembled correctly when it was closed after the battery change as well. Some movements have a small metal flap that the buttons push against to work the functions. If the flaps get moved then the button might be pushed in and stuck since the flap doesnt push the button back out...OR...there is a tiny little c-clip that holds the button in place and if thats removed then the button might not push back out or could come out of the case all together!
So...check around the button for a build up of dirt first, try removing the dirt with a pin or small screwdriver. If the button comes out then put it in a plastic bag along with the watch so you dont get any moisture inside and take it to a reputable watch repair shop! :-)
Jan 18, 2010 | Timex Ironman Triathlon Bodylink Watch...
Re-assembly
With the stainless back off you can see the white plastic cover. To the right of the large battery is a small hole (about 1.5mm in diameter). The spring goes in this hole and presses against the piezo sounder disk that is glued to the inside of the stainless back. Make sure you put the back on the right way up - the word CASIO should be at the top, the same end as the word ILLUMINATOR on the front.
Apr 11, 2009 | Casio AW43-7E1V Wrist Watch
I want to build a watch from scratch. i want all the help possible so not to make to m any mistakes i i have seen all the parts for sale tag would be nice but i am open to all makes, but where to start?...
You are undertaking quite difficult task. I'm not very sure that the assembling the watch from separately bought parts will be cheaper than the complete watch itself.
Anyway, if you decided to do so- go ahead.
First you have to consider what type of watch you want- mechanical or quartz.
Second - what features would you like: simple classical layout, type of seconds hand, chrono layout, maybe with subdials and so on e.t.c.
Let me know all this and I will guide you through all the stages and may even help with part supplies.
Make can be considered later as very many watch parts are interchangeable.
Feb 15, 2009 | Tag Heuer 2000 WK1110.BA0317 Wristwatch
Citizen Eco-Drive chronograph World. Top left button??
It is hard to say not seeing the watch as different watches has different means of push or screw-on buttons. If your watch has a 200 metres mark on dial, then it can be the Helium valve, but it's just a guess. To make sure you'll get the right info, paste this link into your browser:
http://www.citizenwatch.com/CUK/English/identifycaliber.asp
Find your movement caliber number and follow instructions.
If you can't find what you are looking for, upload full watch details here and I will try to find out.
Do not forget to rate, please.
Jan 04, 2009 | Citizen Eco Drive Perpetual Calendar...
Seiko kinetic
Here is a link .
Hope it helps.
Dec 31, 2008 | Seiko Kinetic watch
Accurist watch
Go to the Argos sales counter and ask to see the instruction manual
Jul 24, 2008 | Watches
Bulova Watch Logo
Top Bulova Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Are you a Bulova Watch Expert? Answer questions, earn points and help others
