What is valve at bottom
SOURCE: I have a probally ancient hotwater heater rheem
You will find two covers on the front.Behind each cover the you will find a thermostat ,there will be adail on it. It might be numbers like 120,150 or it might be letters,like A,B,C and so on.You take screw driver and turn to the right until you get the tempture you want.
SOURCE: I have water leaking from the bottom of my waterheater PE50T9A
Turn off the electric and drain the tank. Completely remove the exit valve that is leaking and clean up the threads on the valve and in the hole. Get some plumbers dope and dope up the fitting threads and the threads in the hole and then reattach the exit valve. As a real precaution you may consider taking the plastic valve to the hardware store and getting a replacement one. Also dope that one up good.
SOURCE: I have a Rheem glas fury model 22-40 gas water - leaking
once they leak it's time for a new water heater. ther is no way to repair a tank leak
SOURCE: Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
SOURCE: TRYING TO REPLACE MY OLD RHEEM WATER HEATER MODEL
I would say your water heater is from the fury series; new model number 82V52-2. I've included a link with my solution that you should take a look at. You could also look at water heaters of a different brand if this one isn't available in your area. Kenmore, GE, and Hotpoint are all very good brands of water heaters.
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
