Occurs only when not used for 2 or more days and stops a few seconds after water runs. A new installation 3 years ago & includes Rough Valve with Diverter, Valve Trim, hand shower, and tub spout. NO rust from any other faucet, shower head, or toilet in the house including those which run from same supply line, so not the pipes or water supply.
When you turn off faucets other than your tub or shower you will note that the water stops fairly abruptly. Not so with a shower head or tub spout. Some water always dribbles out even after you have turned it off. This small amount of water then evaporates leaving behind the iron that was dissolved in your water. This also happens if any faucet has a slow drip. There are products that will easily remove the rust stains. CLR, Iron Out, or Iron Ike are all good products that will remove the stain. Available at hardware stores, plumbing supply houses, and, ugh, Home Depot or Lowes. Please support your local business owners by purchasing there.
Posted on Aug 11, 2014
SOURCE: Water runs out out both places for spout and shower head in tub!!
One of two issues. Either the shower valve was installed upside down or there is a twin ell ( Old School Diverter) Partially plugged. Odds are the valve is upside down.
Good Luck, Phil
Posted on Dec 09, 2008
SOURCE: water leaks from shower head while bath faucet is running
sometimes there are orings or gaskets that get tore in assembly one of those may be bad,or if it is around the threds you might try wraping teflon tape around the thred once or twice.hope this helps
Posted on Jun 14, 2009
SOURCE: Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Posted on Jul 26, 2009
SOURCE: Bath tub faucet will only run hot. Just started
It sounds like the seals are going bad. Moen is probably rebuildable. You can go to a Menards and ask if they have the replacement guts for your particular model.
Posted on Nov 17, 2009
Testimonial: "Will try waht was suggested. THanks!"
SOURCE: single handle tub faucet will not divert to shower
the diverter on the tub spout is bad you need to replace the tub spout or the pull up diverter if its a separate piece if you have the owners manual with a parts diagram you can order it on line from the manufacturer or a plumbing supply store. you will need to unscrew the tub spoup from the wall to do this use a broom handle or something similar inserted inside the spout and turn it to the left to remove it from the wall
Posted on Dec 03, 2009
Nov 24, 2014 | Price Pfister 8P8-PDKK Pasadena Single...
May 09, 2012 | Danze & Single Handle Tub And Shower...
Mar 08, 2011 | Moen & One Handle Tub & Shower Faucet
Dec 29, 2010 | Cifial 295.604.625.SO Polished Chrome...
Dec 03, 2010 | Delta Home
Apr 27, 2010 | Price Pfister 01-311 Shower Head, Tub...
Jan 05, 2010 | Moen & One Handle Tub & Shower Faucet
Sep 29, 2009 | Delta & Single Handle Shower Faucet
Aug 05, 2009 | Delta & Single Handle Shower Faucet
Oct 26, 2008 | Home
Feb 09, 2019 | Grohe Home
125 people viewed this question
