Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Need diagramof ground drive belt asembly
Belt broke on mower deck need a picture to show the way the belt goes on
Dennis Key
  • Craftsman Master
  • 2,481 Answers
I just put a new one on mine. Your owner's manual has a diagram. Should be a diagram on the deck close to right rear wheel.
Posted on Aug 06, 2014
5 Related Answers
Mr Kelly G
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
Anonymous
  • 5 Answers
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
Posted on Apr 25, 2009
Anonymous
  • 2559 Answers
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
Posted on May 15, 2009
Anonymous
  • 138 Answers
SOURCE: have a power kraft 18.5hp with 46'' deck, need a
first you'll need a model number. look on the underside of the seat, or on the metal plate between the rear wheels for the model no. sticker. wards tractors were made by MTD. there will be two numbers plus the serial number, write 'em both down. then log on to www.milacalawn.com. in most cases, you'll be able to pull up an owner's manual for your tractor with one or the other model numbers
Posted on Aug 30, 2009
Anonymous
  • 15 Answers
SOURCE: need to put deck belt on rally 42
YOU CAN GO TO SEARS.COM TO GET A MANUAL OR THEY HAVE THE BREAKDOWN ON LINE
Posted on Jul 30, 2010
I need a diagram showing how to route a mower deck belt on a John Deere model 240 mower deck. My spring has fallen off and I need to know where it goes to put the tension on the belt.
Here's a link to an online John Deere parts store. When you land on the page, look at the top sub categories for the size of deck your mower has. You should be able to access a parts diagram with pictures of your belt's proper placement.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Mar 07, 2016 | John Deere Garden
How do I replace the drive belt on a john deere 265? There doesn't seem to be a clear answer anywhere. Please help
you can look at the manuel that came with the mower or if you did not get one, go to the JD mower web site and look up you model and download the needed documentation. If that is not possible contact the local JD mower dealer and get a copy of the mower deck docs and look at the instructions for belt replacement.
Aug 03, 2014 | John Deere Service Repair Manual 240 260...
I have an early-2000s Troy Bilt Bronco, 42 inch deck, 18hp Briggs Inotek engine, hydrostatic drive. It broke or threw a drive belt (not for the mower deck, but a transmission belt). How to you go about...
While mowing the yard, the mower went dead. I tried to recrank it and it won't crank. The gas pedal goes straight to the floor and doesn't work to crank the mower. I do not know anything about mowers and don't know where the problem could be. Can someone help?
Jun 14, 2010 | Troy Garden
Hit a peice of metal, now mower won't engage.
The mower engages by an electronic clutch. If it doesn't squeal/smoke/start the mower deck when you try to engage the mower, then the electronic clutch is faulty (you may have sent shrapnel into the clutch), or the belt is cut or damaged enough not to drive the deck. If this problem is indeed associated with the mowing metal problem then you need to visually check under the engine - that's where the electronic clutch that drives the mowerdeck is located. You'll notice that there is a drive belt that goes from the engine to the mowerdeck. That's your drive belt. You should loosen the belt and check the mower deck to see if you can rotate the drive pulley and in turn this rotates the blades (of course you do this with the engine off). That would determine if it's the deck or the clutch that has issues. Your instruction manual will show you how to loosen the belt then try to spin the mower deck drive pulley. If it spins by hand then look back toward the clutch. If the deck doesn't rotate then it needs to be removed so you can flip it belly up to see what's hindering the movement. These decks clog easily, but if clogged when you try to engage the mower deck it will squeal. They're easy to remove (if you have some kind of overhead lift - if not they can be a pain). Good luck
Sep 18, 2009 | Garden
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
Need a routing diagram to install drive belt
go to partstree.com and put your make and model # in then click deck asembly.it should show you what you what you need.hope this helps.
Jul 08, 2009 | Garden
LTX 1000 CRAFTSMAN /42 IN. DECK BELT LODGED ABOVE PULLEY AND STOPPED MOWER AND BROKE BELT. IS THE BELT SIZE 96 OR 97 INCH? THE BELT HAS DONE IT TWICE/STCK BETWEEN THE PULLEY AND THE THING ABOVE IT.
Without the model number, I couldn't tell you what belt goes on the ground drive. That 174883 is a 5/8 x 97" and is your deck drive belt. Your ground drive belt may just need replacing. They will wear thin and loosen up between the pulleys and cause the problems you're having. The old belt may still have the numbers on it.
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Can't figure out how to install main drive belt on riding mower.
Usally if you look on the bottom of of your mower deck it will show you the route you need to go
May 31, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
239 people viewed this question
Top Craftsman Garden Experts
Dennis Key
Dennis Key
john h
Sheldon Dedek
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
