Question about Amazon Kindle Fire HD
My kindle wont turn on
Why wont my kindle turn on
Posted by Kim Marston on
honey
    Master:
  • Amazon Master
  • 262 Answers
There might be some issues with the Battery or the Kindle Device. In the last check the charging port of your device. May be kindle do not charged alternatively you can call the kindle support. Kindle Technical Support Registration 877 690 9305
Posted on Mar 01, 2018
Kindle will not shut off-goes to shut off or cancel but wont move. doesnt charge well-doesnt always hold charge
Patricia, Using the power switch, you can forcibly reset your Kindle device. This reset will shut down the Kindle without accessing the shutdown command from within the Kindle's operating system, a particularly useful tool when dealing with a frozen Kindle. To initiate a hard shutdown, Kindle disconnect from its charger, slide and hold the power switch for about 20 seconds. This will force the Kindle to shut down, now it can be restarted normally.
Check links below for charging problems.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reset Kindle Fire When it Won Turn on or Charge
Troubleshooting Kindle Fire That Won Charge
Kindle Fire not charging
9 common problems with the Kindle Fire HD and how to fix them
Feb 25, 2016 | Amazon Kindle Fire HD
My keyboard is not lighting up
Kindle keyboard is not lighting up
Jan 08, 2016 | Tablets & eReaders
How do I get my kindle to switch off
if it's left turned on, it will turn off when the battery runs out.
Jan 29, 2015 | Amazon Kindle - 6 Inch E Ink Display...
Can't turn my kindle on
Mine done the same thing. I opened up the kindle and disconnected the battery plug for a few minutes. It worked after that.
Aug 06, 2014 | Amazon Kindle Fire HD
I have a kindle that wont come on an its charge up
First off, I've had 5+ of that type of kindle. Each time the screen was cracked causing the screen to not turn on. If you see any lines this is definitely your problem. If so, you can either replace the screen or replace the kindle.
Mar 11, 2014 | Amazon Kindle 3G
My kindle fire pg is sideways and will not turn upright..what do Indo?
You have asked about the Kindle eReader, but your question refers to a Kindle FIRE.
On the eReader touch the Aa button and select the correct orientation that you require.
On the FIRE drag down from the top to reveal the top MENU - select the CIRCLE icon on the left which is the SCREEN LOCK icon. Turn it off.
Mar 03, 2014 | Amazon Kindle 3G
My kindle wont charge while I'm using it. It only charges when the kindle is off
You didn't specify the model of your Kindle, but the user guide for my Kindle states that it must be turned off to charge.
Sep 21, 2013 | Tablets & eReaders
The kindle won't turn on
It is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't turn on at all this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
Dec 31, 2012 | Amazon Kindle Fire HD
`kindle fire
Sounds like your power cord is dead and that it's not charging. If it's new bring it back to the store you bought it from and get a new one.
May 15, 2012 | Amazon Kindle Fire
Amazon Kindle Fire HD Logo
383 people viewed this question
Top Amazon Tablets & eReaders Experts
Ron Rak
Ron Rak
Marvin
Marvin
Jean Thiebaux
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
