Question about Electrolux 23 in. ESI6104 Built-in Dishwasher
Dishwasher wont fill up with water - Electrolux 23 in. ESI6104 Built-in Dishwasher
  •  Gary Gemmell
    Gary Gemmell Nov 03, 2015
    Blocked water inlet pipe or faulty main board.
Dado
    Master:
  • Electrolux Master
  • 511 Answers
When you start the dishwasher you have probably noticed that it first drains water and is very important to hear that drain pump running all the time or stops after a while? Why?
If the drain pump runs constantly then the fault is in the phase of "drain water" or is activated anti-flood system. Reset point of pressostat is not reached after max. 120secs. Programme stop and can be continued after error remedy by pressing the programme key.
If the pump is running for a while and then stops, then the fault is in phase "fill up water". Switchpoint of pressostat is not reached
after max. 60 secs.
Usually built-in dishwashers has anti-flood system that responds in the event of water in the bottom of the dishwasher. Such a case, find and repair water leaks.
Dado
Posted on Jan 03, 2015
Maytag dishwasher wont fill
Some dishwashers have a float inside that shuts off the water when it reaches a certain level check to see that the float is not stuck in the high water ( off ) position. Hope this helps.
Dec 29, 2013 | Dishwashers
Water wont stop filling up
If water keeps filling or dribbling into the machine with the power off it's the water inlet solenoid. If it overfills only during the cycle then it is the pressure switch or pressure switch tube.
Jul 10, 2013 | Meiko Dishwashers
My dishwsaher wont drain water
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 10, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
My neff dishwasher is not filling with water
Hello
Water inlet valve is responsible for filling water in your dishwasher, when that goes bad either the dishwasher wont fill at all or will fill the water slowly. Please check the inlet screens and also try to clean the water lines for any clogs/obstructions. Please get back to me if you have any other questions.
Kevin
Nov 11, 2010 | Neff Dishwashers
My hotpoint dishwasher wont go past filling up, but its doesnt fill!!
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Aug 19, 2010 | Hotpoint 23 in. BFV62 Built-in Dishwasher
Dishwasher wont fill with water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Sep 11, 2009 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
I fit won't fill then apparently you're not getting any water to it, which means it not's fixed. Did you turn the service valve back on since the repairs were made? Sometime when you turn a service valve off they fail to re-open. Crack the inlet water line and verify that you have incoming water.
Jan 18, 2009 | Whirlpool 24 in. DU1050SS Built-in...
Dishwasher wont fill.
Sep 29, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Diswasher wont fill
Faulty fill valve?
Timeing out with insufficient flow of water?
Hot water to hot and locking up valve?
Apr 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Electrolux 23 in. ESI6104 Built-in Dishwasher Logo
Top Electrolux Dishwashers Experts
Mike
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
