Question about RCA 20V500T 20" TV
Does my RCA 20V500t have a digital tuner? - RCA 20V500T 20" TV
2 Related Answers
ABRsvcs
  • 4234 Answers
SOURCE: digital or analog tuner
Your set has a NTSC tuner for the over air broadcasts. You will need a converter box if you wish to use an antenna. If you have cable or satellite, you are fine.
Dan
Posted on Sep 01, 2009
ladywinn
ladywinn
  • 5138 Answers
SOURCE: how do you remove the fpa mode off your 20v500t rca tv?
By Pressing CH+ and VOL+_ at same time
Posted on Dec 24, 2009
My RCA 20V500T turns itself on and off. I heard it might be a cold solder joint. If so where would it be?
The dry solder might be in horizontal section
Check the out put transistor pins / Driver cct. / FBT pins.
Jun 03, 2011 | RCA 20V500T 20" TV
What is the code for RCA tv model number: 20V500T
Hello
You just try one amoung these codes.
RCA Codes: 000/ 003/ 004/ 005/ 007/ 009/ 011/ 048/ 078/ 082/ 083/ 094/ 096/ 098/ 099/ 101/ 102/ 103/ 107/ 113/ 129/ 133/ 167/ 179/ 181/ 187/ 188/ 194
Nov 11, 2010 | RCA 20V500T 20" TV
FDA Lock is on RCA Model 20V500T
Try unpluging for five ninutes the after plugging back in press and hold power button for 10 seconds...this should reset it!
Dec 18, 2008 | RCA 20V500T 20" TV
Tv rca
change the speaker maybe it's busted
Oct 14, 2008 | RCA 20V500T 20" TV
Black screen
BAD SOLDER JOINTS ON FLYBACK TRANSFORMER,RESOLDER FLYBACK,IT FIX MY PROBLEM
Aug 25, 2008 | RCA 20V500T 20" TV
Rca 20v500t model
Need more Info. Try moving the cable connection on back of TV.
Jun 20, 2008 | RCA 20V500T 20" TV
RCA 20V500t
open R510 on video card replace resistor value 18k ohms @2 watts
Oct 12, 2007 | RCA 20V500T 20" TV
RCA 20V500T HALF PICTURE AND SHUTSDOWN
Try , Horizontal or Vertical output.
Sep 09, 2007 | RCA 20V500T 20" TV
Televison & Video Logo
Top RCA Televison & Video Experts
Paul Bade
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
