Question about Brand Remote Start/keyless/car Alarm Very Sleek
Pursuit 9644i how to turn off alarm horn blowing.
Why horn keeps blowing on 1986 porsche 911?
hi there
The horn is blowing while you turn your steering wheel ,correct?
when you took of the horn button it was still blowing?Do you have an alarm from factory on the car?
ivan
[email protected]
Sep 09, 2014 | 1986 Porsche 911
How to turn off the pro alarm
I would start by replacing the FOB. Sounds to like the electronics inside it are bad. The only reason the horns would go off is if you hit the panic button. There is a slight chance the receiver is bad. But Fobs are cheaper to replace than the receivers. If you have two FOBs and they both react the same, then replace the receiver. Or just ditch the system. The keys (in the door locks) should still activate the alarm system.
Aug 07, 2014 | 2011 Chevrolet Silverado 1500
Horn blows fuse
Sounds like a short circuit make sure your using proper fuses and what not.
Dec 31, 2012 | 2005 Jaguar S-Type
Horn doesn't blow but does with alarm
Usually a sign the horn pad under the air bag is not working, or a wiring problem between the horn pad and the horn relay.
Sep 20, 2012 | 1999 Dodge Caravan
2009 honda civic lights flashing horn blowing security alarm
try disconnecting the battery neg lead and the pos lead then join them together for 5 mins then reconnect the battery and see what happens ,it might just reset the fault for you .
Apr 27, 2012 | 2009 Honda Civic 1.4
My 91 caprice horn does'nt work from the steering wheel but when my alarm goes off it blows
You have 2 point of contact one is the alarm and the other is the horn switch itself, the horn switch is non op,
Mar 12, 2012 | Cars & Trucks
When i start my 2006 chrysler 300c the horn will sound and will not stop till i turn the car off
Sounds like you have a problem with the alarm system. Does it beep, or blow at a steady keel? If it beeps, alarm, if it blows steady, look for a stuck horn pad.
Jun 09, 2009 | 2006 Chrysler 300
Horn starts blowing randomly
do you have a alarm on it. If so you need to disable it or turn it off. Other wise you have a short somewhere in your horn. disconnect the horn under the hood. Its usually upfront and looks llike a flat black circular device that has one wire going to it, unless you have a alarm then it may have more.
tepfy
Jan 27, 2009 | 2002 Lincoln LS
Brand Remote Start/keyless/car Alarm Very Sleek Logo
Top Spy Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Kardoc
Mr.Mike
Are you a Spy Vehicle Part and Accessory Expert? Answer questions, earn points and help others
