Question about Lite On Computers & Internet
What is his called < > ? - Lite On Computers & Internet
Sharron Krieger
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 156 Answers
Type that question in the search on your computer
Posted on Aug 15, 2014
I need firing order on 1998 Suzuki swift on plugs and cole pack
;post engine sizes? they used 3 engine, or more world wide
if it has a 4 wire pack the engine firing order is fixed by ecu
1342
but the COIL PACK must not be scrambled.
replace wires 1 by 1. (if new pack, mark old first)
if lost the org. pack is marked, 1,2,3,4 , if not you need
the marks, out of FSM or maker of new coil.
here is the list of engines, ;pick one>?
1.0 L G10 (LP2) I3
1.0 L G10T (LS3) turbo I3
1.3 L G13A/BA (L72) 8V I4
1.3 L G13B/G13K 16V DOHC I4
1.5 L G15A 16V I4
1.6 L G16 16V I4
if you cant use alldata.com to see that.
or cant use suzuki pit stop plus for $4
then google for your engine. and pray.
i can guess, because i can see the 2 coils there. in pack
and they are in series like this
1 <><><><><><<4 (series wound) the plastic case telsl me. this.
2><><><><><<> 3.
or group 2
2><<><><3
1><><<>>4
see? so try 1 ontop, run ok
no
try 1 in group 2.
this is called wasted spark
1 and 4 fire together.
then 2 and 3 as one;
so if 1 is connected right and 2,
then 2 and 3 must work if 1 fires right, see?
as you can see only #1 maters. if you now the coil end to end wiring.
tell country and engine, and all this is 100x more easy.
but ive never ever had to look it up.
the coil packs are obvious wired a certain way.
all in 2 guesses.
Jan 22, 2015 | Suzuki Cars & Trucks
Hello I am shafiq. Can you send me the unlock code for iphone 5
Hello. Do you want to unlock your iPhone 5 from network restriction.? If so, you can visit SimpleUnlocking.com and get the remote unlocking service. This method of unlocking an iPhone is safe, simple, affordable, quick and permanent. It doesn't require a jailbreak too. Good luck.
.................UNLOCKING INSTRUCTIONS.................
1. Wait for us to send you an email saying your phone has been activated or remotely unlocked.
2. Install the latest version of iTunes.
3. Make sure your Apple iPhone 5 phone software is updated to the latest version using the iTunes software.
4. Connect your Apple iPhone 5 to iTunes with a NOT ACCEPTED SIM card.
5. Wait until iTunes detects your Apple iPhone 5.
6. Disconnect your Apple iPhone 5 and reconnect it after 10 seconds.
7. Your Apple iPhone 5 is now unlocked.
Nov 21, 2014 | Cell Phones
How to reinstall authourity certificates of nokia
1. Create a New Folder on your desktop and call it whatever you like.
2. Open notepad on your computer.
3. Copy the text below into the Notpad file. (I got this from some website as they were using it for smething else but it does work so thanks to them or thanks to you if this is yours)<?xml version="1.0"?>
<!DOCTYPE html PUBLIC "-//WAPFORUM//DTD XHTML Mobile 1.0//EN" "http://www.wapforum.org/DTD/xhtml-mobile10.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>Install root CA</title>
</head>
<body>
<p>
<a href="der1.cer">Download a CA Cert1</a>
<a href="der2.cer">Download a CA Cert2</a>
<a href="der3.cer">Download a CA Cert3</a>
<a href="der4.cer">Download a CA Cert4</a>
<a href="der5.cer">Download a CA Cert5</a>
<a href="der6.cer">Download a CA Cert6</a>
<a href="der7.cer">Download a CA Cert7</a>
<a href="der8.cer">Download a CA Cert8</a>
<a href="der9.cer">Download a CA Cert9</a>
<a href="der10.cer">Download a CA Cert10</a>
<a href="der11.cer">Download a CA Cert11</a>
</p>
</body>
</html>
4. Save the Notpad file as type ALL FILES but when naming it just call it cert.html and save it to the folder you created on your desktop earlier.
5. Now downlaod the Root Certificates you need to the same folder on your Desktop.
6. When saving the first Certificate to the folder call it der1 ((make sure not to take out the file extension eg .cer))then the second der2, third der3 and so on and so on till you get to der11. (Dont worry this will not rename the certificate when it installs on your phone.)Example of what the files in your Desktop folder should be called der1.cer, der2.cer etc etc.
7. Now transfer the whole folder from your Desktop to your Mobile phone. (I did this by using Nokia PC Suite.)8. When the folder with the certificates and hmtl we made have been transfered to you phone navigate using your phone to that folder.
9. Go into the folder and open the cert.html file. (Your browser will now open a page with 11 download links available)10. Now all you have to do is click on each link and accept each certificate remembering to save and they will install on your phone. (On my 6500 Classic i can check this by Navigating through my phone to Menu>Settings>Security>Authority Certificates)Notes:- Some errors you may receive when trying to download the certificates through your phone browser may be Already Exists, Expired Certificate and the most annoying is Corrupted Certificate.
Already Exists - Shouldt allow you to save (DO NOT SAVE IF IT ALLOWS YOU)
Expired Certificate - (DO NOT SAVE)
Corrupted Certificate - Install the certificate on your computer first, then go to Tools>Internet Options>Content>Certificates.
(save the certificate to other people tab) Browse for the certificate you installed then export it in DER format to the Desktop Folder you created then start process over again to get it onto your phone.
Remember to delete any certificates as you go that you have already installed so you dont get mixed up
Oct 21, 2014 | Nokia Cell Phones
I have a samsung s3 gt-i9300 i cant make or get
Your Samsung Galaxy S3 must be restricted to some specific network. That is why it allows only emergency calls when a SIM card from some other network is inserted in. You need to unlock your Samsung Galaxy S3 to make it work with all SIM cards. You can unlock your Samsung Galaxy S3 safer and easier using unlock code. You can get the accurate unlock code for a Samsung Galaxy S3 from Unlock-Zone.com at affordable cost. Good luck.
Method 1:
1 - Switch ON your Samsung Galaxy S3 with a NOT ACCEPTED SIM Card.
2 - Samsung Galaxy S3 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung Galaxy S3 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung Galaxy S3.
3 - Compose : #0111*CODE#.
SOURCE: MobileUnlockGuide.com
Oct 02, 2014 | Samsung Cell Phones
Can I get my NCK code for IMEI 356192035407829 huawwi u7519
You will have to call Huawei support in your local area or the phone company that provides your mobile service.
Aug 07, 2014 | Cell Phones
Wont spray, no triger noise
<p>Need to know what model you have....</p>
<p>Do you have an <a href="http://www.rainvac.com/aquamate-model-am12-silver">AquaMate, Model AM12 (Silver)</a></p>
<p>or an <a href="http://www.rainvac.com/aquamate-ii">Aquamate II </a></p>
<p>or <a href="http://www.rainvac.com/aquamate-i-refurbished">Aquamate I</a>...</p>
<p>Let us know or call us to speak to a Rainbow Specialist.</p>
<p>RainVac </p>
<p><a href="www.rainvac.com">www.rainvac.com</a></p>
<p>800-523-0510</p>
Nov 04, 2012 | Rainbow E series Canister Wet/Dry Vacuum
How do I print a single call report for a FAX previously sent
Printing a fax call report
A fax call report is a brief report that indicates the status of the last fax that was sent or received.
To print a fax call report
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Reports, and then press .
3. Use the < or the > button to select Fax Call report, and then press .
4. Press to select Print report now. The all-in-one exits the menu settings and prints the report.
NOTE To set the fax call report to print automatically, see Setting print times for the fax call
report.
Setting print times for the fax call report
You can set the all-in-one to print a fax call report after any of the following events:
? Every fax error (the factory-set default)
? Send fax error
? Receive fax error
? Every fax
? Send fax only
? Never
NOTE If you select Never, you will have no indication that a fax failed to be transmitted
unless you print a fax activity log.
To set the print times for the fax call report
Use the following steps to set when the fax call report is printed:
4. Press the > button once to select Print report, and then press .
5. Use the < or the > button to select the option for when you want the fax call reports to be printed.
6. Press to save your selection.
The following print-time options are available:
Including the first page of each fax on the fax call report
If this option is turned on and the page image still exists in the all-in-one memory, the fax call report
includes a thumbnail (50% reduction) of the first page of the most recent fax that was sent or
received. The factory-set default for this option is On.
To include the first page of each fax on the fax call report
Use the following steps to include the first page of each fax on the fax call report:
4. Use the < or the > button to select Include 1st page, and then press .
5. Use the < or the > button to select On or Off, and then press to confirm your selection.
Jul 06, 2011 | HP LaserJet 3050 All-In-One Printer
This the messagethat got Content-Type: text/plain; charset=iso-8859-1 Content-Transfer-Encoding: quoted-printable I'm trying=A0 to connect with you for a very long time, why don't you call = me or...
That is and HTML message that may not have been assembled correctly by the sender or corrupted during transmission and reception. That is not rare.
Nov 06, 2009 | Yahoo Mail
Computers & Internet Logo
Top Lite On Computers & Internet Experts
Vernon Taylor
ray gallant
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
