Question about Master 1500ID Combination Padlock
How do I get it back open when it won't open to the combination I gave it?
Grady Turner
    Scholar:
    New Friend:
  • 101 Answers
Make sure you push the shackle down firmly to clear the lock and try the combo again. It is possible to open it by trial and error, but not easy. I have removed the security screws and repaired one, but it was tricky to reassemble. The problem with mine was a spring that slipped out of position and the lock wouldn't reset correctly. There are a lot of parts inside, so chances of getting it to work correctly are not good unless you're really good with complex mechanisms and puzzles.
Posted on Aug 07, 2014
Safe(DSW3607). Battery is working but door won't open when combination is entered. It stuck in the past but I was able to open it eventually. Now it appears as though the handle will not turn all
Internal batter is low...look for two pin points on the outside of the combo and attatch a new battery temporairly then work combo. Insert new battery when you get it open. Hope this helps Ed
Oct 02, 2012 | Sentry Fireproof Safe
I got the master lock speed dial combination lock but forgot my combination and it won't open. can somebody please tell me if i can reset the password?
1. Contact Masterlock.com and fill out the form, get it notarized and send it in for the combination to unlock it based on the S/N which is on the lock.(http://www.masterlock.com/faq/LostCombinations/). Good luck on this since Masterlock will end up finding something that will prevent them from giving you the combination. Its quite frustrating and NOT worth the trouble.
2. Go to home depot. Buy a 24in bolt cutter ($22) cut the stem of the lock. and replace with a new lock that you can buy from home depot for $ 29.00. If you have a key that is inside the lock box that you really need, You will now need to drill out the combinations piece by piece and the door will pop open or send the lock back to Masterlock. They will retrieve the key for you and send it back.
Aug 27, 2012 | Master Lock 5400d: Portable Select Access...
My keyboard won't light up on an ASIA G73J. I have tried the function keys and they won't work.
Did you hold down the [fn] key, in combination with the function keys? If not, you have to hold down the [fn] key in combination with pressing the function key's that are associated with the keyboard back-lighting (usually [F3] or [F4] on an ASUS G-series).
Aug 03, 2011 | ASUS G73JHA1 Notebook
I have a Sentry safe and I do have the key but lost the combination...why won't the key work to open the safe?
Because you lost the combination of it, you can't use it with your keys alone.
Jul 04, 2011 | Home Security
My sentry safe
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
Feb 06, 2008 | Sentry Fireproof Safe
Resetting the combination
The reset works when the current correct combination is set on the front. If you forgot the combination, you can go to the www.masterlock.com and download a PDF to request a combination from the factory to open it. It requires a notarized form & takes 6+ weeks. In the end, it is probably easier to buy a new one. When resetting the combo, I accidently scrambled it as I flipped it over. And did not know the combo. The reset button would not work. I did some guess work around the setting and got it to release again.
Jan 08, 2008 | Master Lock 5400d: Portable Select Access...
Master 1500ID Combination Padlock Logo
355 people viewed this question
Top Master Locks & Locksmithing Experts
ray gallant
Tom Chichester
Chris Walker
Chris Walker
Are you a Master Lock and Locksmithing Expert? Answer questions, earn points and help others
