Question about OKI C Office Equipment & Supplies
No error is displayed
SOURCE: HP 2600n prints black streaks on a page
Could be a few things but black cartridge is most common cause, they are not "cleanable" one just replaces them, if you carts are non gen HP then that will surely be your problem, slight chance could be transfer belt assy or fuser. they are also just a case of replacing, go for cart, replace it and see.
Posted on Dec 05, 2007
SOURCE: BLACK SMUDGING
Hmm... This sounds like it is a toner problem. If your roller is getting too much toner then it just globs it onto the paper even though the drum is not asking for it. Are you using a new toner cartridge or a re-filled one? Is it from Brother or a 3rd party? I suggest you remove the toner cartridge and check inside the printer. Clean any spilled toner. Check the toner cartridge for leaks .. give it a good shake and see if it is leaking. If you have another toner cartridge, you can replace it to test. You may need to pint a few pages to see a change. Another test could be to print a few (2-5) "BLANK" pages. The printer should not be depositing any toner. If no smudge or the smudge stays the same, then the toner cartridge is the likely problem. If the smudge is there, but gets smaller, then clean your printer.
Posted on Jan 11, 2008
SOURCE: Black smudge marks along left side edge of paper.
Its probably a defective toner. If the film on the toner drum is scratched it can cause toner to stick to the drum everytime it spins causing the constant marks.
Posted on Jul 30, 2008
SOURCE: BLACK INK SMUDGE ON RIGHT SIDE OF PAPER IN 3
Although they are quite pricey, it sounds like a new toner cartridge is in order.
Posted on Jun 11, 2009
SOURCE: Pringed Pages are coming out with yellow and blue smudges on edge
I have also had this problem which I solved by changing the photoconductors of the colours shown.
you can try this.I am not sure if that is the best solution but it solved my problem
Posted on Jun 18, 2009
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
Dec 14, 2013 | Brother MFC-8460N All-In-One Printer
Sep 29, 2013 | OKI C Office Equipment & Supplies
Sep 05, 2012 | Canon imageRUNNER 1023iF Black and White...
Aug 17, 2012 | Cisco Oki C330Dn Led Printer - Color -...
May 21, 2010 | HP LaserJet 3030 All-In-One Printer
Apr 07, 2009 | HP Color LaserJet 2600n Printer
Jul 08, 2008 | HP LaserJet 1320 Printer
May 13, 2008 | Xerox WorkCentre XD120F Laser Printer
337 people viewed this question
