Question about Jacuzzi Home
Water continues to run problem - Jacuzzi Home
Nick
    Sergeant:
    Habit-Forming:
  • 129 Answers
Could be a stuck or old and leaky flapper
Could be a clogged valve
Could be an old in need of replacement valve
Could be a number of other things depending on what kind of toilet and hardware you have
Residential or commercial?
Ball cock and flapper? Or newer style internal float valve?
Posted on Aug 11, 2014
Washing machine continually running water
the water valve that connects the inlet hoses to the machine is stuck open and needs to be replaced if the water continues to run after you have turned the machine off
Apr 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
Aprilaire 600 humidier: water continuously runs
sounds like you may have it wired to a continuous power source vs one that shuts off with the furnace. The most common wiring is red to C & white to W
Jan 08, 2010 | Aprilaire 600 Humidifier
Water runs continually
No it should only run when the unit is on
Nov 14, 2009 | Aprilaire 600 Humidifier
Cold water runs continuously at end of cycle
If yo9u were to unplug the machine at that point and the water continues to run in you have a bad water valve. If it stops when yoou unplug it, it may be the timer. Would have to test to see if voltage is present at the valve in the second scenario,. Water valve part# is WH13x10024 @ $51.00
Apr 08, 2009 | GE WJSR2070B Top Load Washer
Replacing water fitting assembly
water dispenser continues to run too long after removing glass
Oct 23, 2008 | Refrigerators
Rinnai water heater continually running
the rinnai comes on when water starts flowing through the unit.
Apr 08, 2008 | Heating & Cooling
Water won't stop running
It might have a small stone or something similar in the water soleniod valve or it might just be sticking open somewhat. I'd go ahead and change the cold water soleniod valve because it's not closing itself and shutting off the water flow.
Jan 08, 2008 | Maytag Performa PAV2200
The water continues to drip after the ice cube maker is full.
Sounds like the water fill solenoid valve is leaking by. You will have to change that solenoid valve if the water continues to drip into the ice maker tray after a normal fill cycle. http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=JCD2295HES&mfgModelNum=JCD2295HES&fkMfgID=1
Dec 05, 2006 | Jenn-Air JCD2295HES Side by Side...
Home Logo
109 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
