Question about HP Deskjet 3510 e-All-in-One Printer
How do I remove the lid on my HP 3510
I need to scan large documents and need to have them lay flat. How do I remove the lid to make this possible?
Posted by Barb on
5 Related Answers
Anonymous
  • 51 Answers
SOURCE: Scanning docs & size of pdf files on Mac w/HP l7680 All-in-one
The scanner produces a "picture" of the document, much as if you laid it flat on a table and took a picture of it with your digital camera. If you did this, your .jpg from the camera would be several hundred K at a minimum - comparable to the file size off the scanner. That's why the file is so big, it contains a picture and not text data - even though it's still a .jpg file.
If you reduce the scan resolution you will save space, but at the expense of legibility of the document image. To get it down to the smallest possible size, you will need to run the scanned image through OCR ( Optical Character Recognition ) into a Word document for example, and then print it out to a .pdf file. If you have a clean source document with few graphics this isn't as difficult as it may seem. Microsoft Office has an excellent OCR process known as Document Imaging. You need to carefully proof read the result but with a clean input Document Imaging is amazingly accurate in Office 2007.
In short, there is no easy solution to your problem.
Posted on Dec 31, 2008
Paras Sagarawat
  • 84 Answers
SOURCE: I have HP Officejet 4355 and want to use it for
open the top covers put the paper(s) in the automatic document feeder, use the software to scan and viola............ u wikk get them scanned....
Posted on May 14, 2009
wheatlandsvc
Edwin Martens
  • 1110 Answers
SOURCE: Problem with size of scanned document using HP laserjet 3380
It depends also on what you are scanning....half tones, pictures etc. but the easiest way to control the file size of PDF's is to change the resolution setting. Also referred to as the quality setting. These are settings like Super Fine, Fine, Standard. It should be right on your control panel. It is the same setting you can change when sending a fax. If your default setting is Fine for example, changing it to standard will use a lower resolution and reduce the file size. In other words the higher resolution/quality setting you use make the file size much larger.
Good Luck and Thank You for using Fixya.
Posted on Apr 06, 2010
Anonymous
  • 118 Answers
SOURCE: how to remove a large black line in middle of
unplug printer cables, replug in
take cartridges out, put back in making sure sure nothing is obstructing the ink dispensary on the cartridges and that they're clean
look in the printer where the cartridges go, making sure nothing is blocking the ink
check the rollers to make sure no paper is caught inside the printer
turn on printer and try this
hope this works and good luck
Posted on Apr 30, 2010
Joed911
JDTec
  • 4338 Answers
SOURCE: I have an HP Officejet
Lift the scanner top, then look at the narrow pane of glass. There probably is a spek of dust or ink on it. Clean it with alcohol. I've had to remove the glass, due to the speck being on the undersaide of the glass.
Also, lift the ADF cover and clan the rollers with a damp cloth.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jul 17, 2011
How do you remove the lid from the scanner
Maximum scan size from glass: 21.6 x 29.7 cm (8.5 x 11.7 inches)
Aug 05, 2014 | HP Deskjet 3510 e-All-in-One Printer
Why are pages scanning with lines running through them, but printing perfectly fine?
Try cleaning the rollers. Usually you have to remove the cartridge to get to the rollers that moves the paper.
May 02, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
Scanner lid hinge broken or missing
If you read through the posts, there are many ideas on what to do. The cheapest and easiest way I found to fix a broken hinge is to follow one the ideas in the posts. I wrote a detailed post step-by-step. In quick summary, I broke the other hinge and removed all the broken pieces to both, so the lid would lay flat again. Printer doesn't care if the hinges are not there. The manual is on line:http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&dlc=en&document=&product=3635378 Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
Apr 01, 2014 | HP Officejet 6700 Premium E-All-In-One
How to scan a document
turn on your scanner
click start all programs look for your scanner open it up
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it and what format browse select the file/folder where you want to save it (my pictures) most common
hope this helps
don
Feb 11, 2011 | HP OfficeJet 6110 All-In-One InkJet...
How do i scan scanning
lift the lid on your scanner lay the photo face down then select preview or scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
hope this helps
Jan 23, 2011 | HP PSC 1610 All-In-One InkJet Printer
HOW DO i SCAN A DOC.AND SAVE IT TO A FILE
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
hope this helps
Dec 07, 2010 | HP DeskJet F380 All-In-One Printer
How do use the Scanning Feature ?
navigate to your scanner through cannon utilities lift the lid lay a document/paper face print side down then press preview document which will scan document after this you will have to save this document somewhere
hope this helps
Sep 20, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Lines on my copies
As the page you wish to copy goes through the document feeder, it passes the scanner as well as a white plastic band that the scanner "compares" the dark writing or data on the page to. If this white plastic band is not very clean, the scanner reads the dirt as if it is part of the image you are scanning. Try cleaning the band as thoroughly as possible, as well as the small piece of glass to the left of the larger glass on the flat bed scanner. Make another copy to test your results.
Hope this helps!
May 07, 2009 | HP LaserJet M5025 MFP All-In-One Printer
Dec 30, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Deskjet 3510 e-All-in-One Printer Logo
k24674
Mike
