Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
i think you are able too see the video in play back mode. so there is no problem in your LCD. i think the CCD has got damaged in your CAM. that is why you are not able to view anything in shooting mode. because CCD is the layer which converts the light falling on it to a electrical signal and shows us as a complete image.
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
* Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step. * It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
1. Ensure the lens cap on the front of the camcorder has been removed. 2. Ensure a fully-charged battery is inserted in the camcorder. 3. Ensure the STANDBY/LOCK switch is set to the STANDBY position. 4. Turn on the camcorder and set it to the CAMERA mode. 5. Look to see if an image can be seen in the viewfinder or LCD. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed. 6. If the issue is not resolved, reset the camcorder to factory specifications. NOTE: If the issue is still unresolved after completing the troubleshooting steps, service may be required .
Click the "disp" button. The display of the camera has been turned off in the LCD screen but you can still use the viewfinder, this functionality is just for those who prefer to use the viewfinder instead of the LCD screen.
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
This is problem of defective ccd imager and ccd imager needs to be replaced. canon will replace it free of cost as Canon announced scheme of free ccd replacement scheme for few models. Check Canon ccd advisory for details. Thank you.
"Live View", where you can see and compose your picture on the LCD, was not available on any digital SLR before 2007 (the Rebel XTi came out in late 2006). So you need to compose your picture using the optical viewfinder, take your picture, and the picture shows up on the LCD after you've taken it.
But it's still faster than having to wait until the film is developed. :-)
