Question about Carrier Heating & Cooling
My Carrier A/C split Model 38KCL112313GP has error code E1 displayed. What does it mean?
SOURCE: E1 error code
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Posted on Jun 05, 2008
SOURCE: yonan ac split mini 1.5 ton error codes E1
CHECK ROLLOUT SWITCH AND CHECK FOR A POSSIBLE
GROUND FAULT..OR FUSE..
Posted on Apr 13, 2010
SOURCE: error code E1 54 on samsung air conditioner split
A Bit of a late reply but E1 54, is indoor fan fault.
Posted on Feb 09, 2011
SOURCE: kenstar split airconditioner display E6 error what does this mean
Kenstar is displaying F8 error
Posted on Mar 20, 2011
SOURCE: The meaning of display Error Code-E1
MY SAMSUNG WINDOW AC SHOWS E1 .HOW TO RESOLVE IT
Posted on May 02, 2011
Jul 30, 2018 | Carrier Heating & Cooling
Apr 14, 2016 | Frigidaire Heating & Cooling
Feb 14, 2015 | Carrier Heating & Cooling
Aug 05, 2014 | Carrier Heating & Cooling
Jul 27, 2011 | Carrier 36KCARMS Air Conditioner
Mar 10, 2010 | Carrier Heating & Cooling
Aug 09, 2009 | Carrier Heating & Cooling
1,943 people viewed this question
