Question about Activision Video Game Consoles & Games
How do I create your own skylander
My own series: construction army
Posted by Matthew Lam on
We have lost a skylanders trap with kaos inside. if we buy a new one kaos will not be inside. any ideas??
No because each Skylander has its own memory to save your data...also traps save there own info...so a new trap will be empty...sorry to say. But that's how they work
Aug 16, 2015 | We Video Game Consoles & Games
Portal on skylanders trap team says character has a problem, how can I get it to work
Unfortunately you have to replace the Skylander or the portal itself. If the portal will not recognize any other Skylanders then fortunately for you it is only the portal that needs to be replaced. If it will read the information from others then the character must be replaced, and more to the point... so will any work/gameplay you dumped into the toy. Like any other piece of computer data, the information maintained in a Skylander can become corrupted or wiped.
Mar 20, 2015 | HOW Video Game Consoles & Games
My skylader from spyro's adventure has an error, what do I do?
If you are getting an error stating A toy on the Portal of Power has a problem, follow these steps to reset your broken toy.
Skylanders SWAP Force
  1. With the toy on the Portal, select Pause.
  2. Select Skylander.
  3. Select Manage.
  4. Select Reset. If you are resetting a swappable toy, you must reset both the Top and the Bottom separately.
Skylanders Giants
  1. Keep the broken Skylanders toy on the Portal of Power and open the Pause Menu.
  2. Return to the Main Menu.
  3. Open Settings.
  4. Select General.
  5. Select Reset Broken Toys.
  6. Select Yes when you are asked to reset the Skylanders toy.
  7. Repeat Steps 5 and 6.
  8. Keep the reset Skylanders toy on the Portal of Power and start a game in Story Mode.
Your Skylanders toy will now work again.
If the screen turns black after returning to the game, try again starting with Step 1.
If the game won't load and you are only seeing an icon on the screen, remove the Skylanders toy from the Portal of Power, put it back on the portal, and try again starting with Step 1.
Jan 26, 2014 | Nintendo Skylanders Spyro’s Adventure...
My skylander on spyro's adventure has a problem, how do I fix it?
Try this :)
  3. Select Manage.
Skylanders Giants
  3. Open Settings.
  4. Select General.
Skylanders swap force game keeps freezing?
if you're running into a freeze on your PS3, just let us know which Skylander you're using, along with when the freeze occurs for you.
If you can, try disconnecting your PS3 from the internet when it freezes then reconnect
Oct 19, 2013 | Skylanders SWAP Force Starter Pack
PORTAL WILL NOT RECOGNIZE CHARACTER
  3. Select Manage.
  4. Select Reset.. If you are resetting a swappable toy, you must reset both the Top and the Bottomseparately.
Skylanders Giants
  3. Open Settings.
  4. Select General.
Sep 02, 2013 | Activision Skylanders: Giants Portal...
Skylanders portal. my skylanders portal wont let me have more than one character on it at a time, how can i play two players?
Yes that is true, a portal of power cannot have 2+ skylanders on it. However, you may be able to use that same technique, but either use two portals, or put your skylanders down one after the other, not all at once.
Jul 29, 2013 | Video Game Consoles & Games
Video Game Consoles & Games Logo
56 people viewed this question
Top Activision Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
