Question about Lenovo 3000 C200 Notebook
When i start lenovo C200 model it shows "Enter CURRENT Password"
How to fix the problem for above issue and how to resolve
JonSnell Electronic
    Top Expert:
  • Lenovo Master
  • 31,761 Answers
Enter the password.
Posted on Aug 05, 2014
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: how can i get a bios bootable cd for the lenovo 3000 c200
external usb floppy
Posted on Jun 15, 2008
sands2499
Dharm Sandhu
  • 18 Answers
SOURCE: Lenovo 3000 C200 shuts off spontaneously
the cpu id over heading not enought cooling you will hav e to get an exteral fan before you damage the board again
Posted on Jul 24, 2008
Anonymous
  • 86 Answers
SOURCE: activateing camera in lenovo Y410 after driver installation.
plz remove all ur camera drivers and then
remove the program USB video device and restart ur laptop and press fn+esc for 2 times after restarting it...........and then insert ur motherboard cd ....it will install the driver automatically
plzzzzzz vote for me
Posted on Oct 05, 2009
reyronald238
ron olf
  • 57 Answers
SOURCE: Experiencing following on boot: Lenovo
Kindly set the BIOS on start up. You may have disabled the USB. If the matter persists then check the drivers in the device manager if they are correctly installed. Or if the problem is your Operating System then have it updated by installing online updates. This would install necessary drivers. If the problem still persists then, look for a computer technician to check your laptop.
Posted on Jan 31, 2011
emissionwiz
Marvin
  • 85239 Answers
SOURCE: runs on battery fine, starts
Hello
It sure sounds like a defective battery to me (one or more dead cells in stack), it takes more voltage to boot up than run once booted, so if the battery is failing that would give the symptom you have. I suggest you have a local Radio Shack test the battery.
Posted on Aug 12, 2011
Why does my game indicate it is loading then reverts to home screen?
Most likely the application has crashed. Follow these steps to resolve:
Do a force reboot (this forces a system check and fixes most issues)
  1. Hold the power and home button at the same time until you see the apple logo (They system is now rebooting)
  2. Once back at your home screen launch the application again
    1. If resolved, awesome!
    2. If not resolved, you may have to uninstall the application and reinstall it.
      1. NOTE: Doing this may cause you to lose your saved games, I suggest backing up the game or syncing it with game center/icloud to save your progress.
    3. If the above did not resolve your issue, contact the application developer/support.
Good Luck!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/thomas_b78b4251cd160cd2
Oct 10, 2015 | Apple iPad Tablets & eReaders
Tip
Unable to Print on HP Printer
There are 2 simple methods to resolve any print job stuck in queue issue. However, both the methods will not fix printing issue if the HP Printer is in Error mode. Make sure your printer is able to print self test page to prove its functionality,
First method.
This Utility program resolve all the printing issue for HP Printers Only ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click ->> HP Print and Scan Doctor to download the Utility and save on Desktop location
Run the HP Print and Scan Doctor file and follow the instruction on screen to fix.
If this does not fix, try the 2nd Method given below ( this is manual process to clear the print job stuck in queue )
This works for all brands of printers ( HP, Canon, Epson, Brother etc )
Click Start > Programs > Accessories > then select Command prompt, then the black window will open and there type NET STOP SPOOLER and hit enter that will confirm service is stopped , after that on the black window type NET START SPOOLER and hit enter. Repeat this step 3-4 times and end the command with NET START SPOOLER and hit enter. Open the Printers folder and Refresh the Window ( Press F5 on the keyboard )
The service will be started and all print queue should already be remove.
// Above given solutions help in resolving print queue issue, however check the printer functionality if it is working fine ( the printer should be in working condition and should be able to print self test page, this utility cannot fix printer hardware issue //
* Please rate this solution with Thumbs up and comment to help us improve providing support
on Jun 15, 2010 | Office Equipment & Supplies
How to fix cursor jumping
Its a driver issue with WIN 8 n a problem that has been going on for some time...
http://www.synaptics.com/resources/drivers
The website above will allow you to download the correct driver to resolve the issue
AK
Jul 17, 2014 | Dell Computers & Internet
Getting error #1208 cartridge error.. just replaced black cartridge with new one and printer has printed about 50 copies prior to this error
http://support.lexmark.com/index?productCode=LEXMARK_X5470&page=techlibraryKB&linkSelected=node2%5Esubnode0&channel=techlibrarykbchannels&locale=EN&userlocale=EN_US follow the above link enter the Product or Software Name as " Lexmark X5470 " enter the Keyword as " How do I fix a "cartridge error" click on filter select the link which says " Troubleshooting a 1203 Error Message on the Lexmark X5400 Series "
forget about the error code mismatch... follow the steps and let me know if the issue is getting resolved
Plz rate me if it resolves ur issue.
Thanks,
Agnel
Mar 15, 2011 | Lexmark X5470 All-In-One InkJet Printer
My hp laptop recently started having a blinking volume bar in the middle of the screen, how do i fix this?
Sounds like there is a problem with your media keys above the keyboard. Sometimes draining the capacitors resets the media keys and resolves this issue. Try disconnecting the battery and ac adapter. After both are disconnected, hold down the power button for at least 10 seconds to drain the capacitors inside the computer. Plug it back in and see what you get. You might need to replace the actual media keys (bezel) to resolve this issue.
Mar 07, 2011 | Computers & Internet
Howo i clean print heads hp b209
Are you getting the error " Printhead problem ' or 'Printhead appears to be missing or damaged " on the printer screen ?
If so, there are few steps to be followed to resolve the issue. I cannot mention the troubleshooting steps with images for Issue, so please click on the link given below to resolve.
Do this step before you follow the steps given in the link and check if this resolve's the issue.
On the Printer SCreen
Press the Setup button
Choose Tools
Choose Clean Printhead
Let the printer go through the process of cleaning.
If the above steps does not fix, click on the link below
Printhead Problem link
Thank you for contacting FixYa
* Please rate this solution with thumbs up and comments
Nov 16, 2010 | HP PHOTOSMART PLUS B209A All-In-One...
Hoe to fix the code 28 & install back the noetworks controller
Hi gregdouglyn.
Let me provide you the detailed troubleshooting steps to resolve this issue.
1) Please press the "Windows+R" keys simultaneously.
2) This should open the Run command window.
3) In the Run command window, please type "devmgmt.msc" and press Enter.
4) Please click on the "Network Adapters" and right-click on the "Network Controller"(Ethernet Driver).
5) Then, select the Un-install option.
6) Click on the "Scan for Hardware changes" option at the top of the Device Manager window.
7) This should re-install the Network Controller Driver.
Performing the above steps should resolve the issue.
If the issue still persists, please perform the below steps:
1) Right-click on the Network Controller Driver.
2) Then, select the "Update Driver Software" option.
3) Then, select the "Browser my Computer for Driver Software" option.
4) Then, in the Search Driver location type "C:\Windows\inf" and also check the "Include Sub-folders" option.
5) Once you have done the above steps, please click on "Next".
6) By doing this, the Operating System will search for the best Driver for Network Controller.
Please perform the above steps.
This should resolve the issue.
Hope this helps.
Please feel free to ask further questions.
Aug 23, 2010 | Computers & Internet
How to Fix Code F3 on GE Oven
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | GE Ovens
How do I fix a IM32FAX.DIl error
1. Uninstall the printer
2. Restart the computer the error message will come again
3. Click start, type regedit in small search bar.
4. Click regedit from the list above. In the Registry Editor, Navigate to the location: HKEY_LOCAL_MACHINE >> SOFTWRE >> MICROSOFT >> WINDOWS >> CURRENT VERSION >> RUN.
In the right pane right click on the “lexmark printer” >> delete and exit the window.
5. Restart the computer.
This should resolve the error during start up.
Method 2:
Try to update the driver which might help you in resolving the issue.
Update a driver for hardware that isn't working properly
http://windows.microsoft.com/en-US/windows-vista/Update-a-driver-for-hardware-that-isnt-working-properly
Method 3:
Follow the instructions in the link below to resolve the printer spooler issue.
Fix printing problems by resetting the print spooler
http://support.microsoft.com/kb/2000007
Apr 20, 2010 | Computers & Internet
Brightness control, Finger print software, disabling tapping
Windows 7 is not set in concrete yet, drivers still being written etc. Ask Microsoft for a fix, or revert back to your previous OS
Oct 06, 2009 | Computers & Internet
Lenovo 3000 C200 Notebook Logo
74 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
