Question about SanDisk Sansa E280 MP3 Player
I have a sansa e280,when i turn it on it says refresh database, half way through refresh, i get a solid screen.how do i get it to restart
5 Related Answers
Anonymous
SOURCE: Refresh database looping
This may not work for everyone - but try inserting a TransFlash (also called Micro SD)card in the microSD slot, and power on. It may then correctly refresh its database. It worked in my case, with firmware ver11.
Posted on Aug 24, 2006
mixmaster
Timothy D
  • 626 Answers
SOURCE: refresh database message
Run the recovery tool from the SanDisk website. Make sure you select format when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Posted on Sep 10, 2007
ceibo
SOURCE: refresh database on screen
how do you put on recovery mode?
Posted on Dec 02, 2007
Anonymous
SOURCE: stuck on refresh database
Simply reset the Sansa e250 by holding the power button down for 10-15 seconds.
Posted on Jan 20, 2008
Jean Sintulaire
  • 758 Answers
SOURCE: SANSA e260 will no longer get further than 25% of refresh database & freezes
I would recommend that you update the firmware on the device..Once the firmware is updated you shouldnt have that problem anymore..I hope that helps
Please rate accordingly
Thank you
COmputerrep
Posted on Mar 21, 2008
Stucked at Refresh database
When the Sansa reads "refreshing database," what it is doing is going through all the songs you've loaded on to it, pulling out the "tag" information (Artist, Album, Song Title, Genre) so it can add this information to its own database which it uses to display the songs to you in its menus.
If it gets stuck during this process, usually it's because of a corrupt song file, or a song file in a format it doesn't understand.
Note that the e280 is only able to play MP3 and WMA audio formats. If you've loaded a different type of audio file onto your Sansa, you'll need to remove them.
If the songs you've recently loaded have all been MP3 and/or WMA, you may have loaded a corrupted file onto your Sansa. Try removing the songs you recently added, and see if the problem goes away.
Feb 27, 2010 | SanDisk Sansa E280 MP3 Player
Can't get past "Refresh Database" Screen
Hi
Try taking it back to the shop.
If not go to http://www.sansa.com/support
Tom
Jul 21, 2009 | SanDisk Sansa e260 MP3 Player
My e280 is frosen on Refresh Database. What do I
Mine did that, and I had to reformat. I believe this is how I did it (note, mine is not a Rhapsody type, that one is different in many respects):http://www.sansacommunity.com/forum/thread/11221/How-to-format-an-e200/
Jun 08, 2009 | SanDisk Sansa E280 MP3 Player
Sansa e260 just stopped working :( I tried the
Try inserting a(n) SD chip into the player and then try restarting. If it gets stuck on the refresh database screen, plug it into your computer. It's the only thing that unfroze my e280.
Feb 21, 2009 | SanDisk Sansa e260 MP3 Player
Refresh Database
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Thank you
Computerrep
Dec 22, 2008 | SanDisk Sansa E280 MP3 Player
Sansa e280 goes to glitch screen after trying to refresh database
if the bar in the middle of the window has stripes its normal and it will keep doing it no-mater wat you do
Oct 26, 2008 | SanDisk Sansa E280 MP3 Player
Sana e280 frozen screen reads Refresh Database
put the player in recovery mode by placing the hold slide button at the top of the player so that the red showes, held down the record button while turning on the player. upon connecting the USB cable the unit will go into the recover mode. Go to my computer and look for the drive which states "16MB Format" and copy the firmware files into it. Disconecting the cable after the files are copied will cause the player to reload the firmware. The player will restart and then shut off because of the Hold button position. Slide the Hold button back into normal mode and push the menu button to restart. The unit will power up and display the language settings. I went to the settings menu and changed the player USB setting to USC. I then placed the player in recovery mode again and went to the MY Computer again and set window to show hidden files. This allowes windows to see the database drive. I then ran chkdsk on the database drive which found a lot of crossed linked files. This then allowed me to delete all the files in the database. Upon comming out of the recovery mode the unit restarted normaly.
You can get the firmware at this site. http://mp3support.sandisk.com/firmware/e200/e200v101.02.18a.zip
Oct 11, 2008 | SanDisk Sansa E280 MP3 Player
E280
Please visit this forum and follow the steps there...
http://www.anythingbutipod.com/forum/showthread.php?t=11233
I hope that help..
Thank you
Computerrep
Oct 02, 2008 | SanDisk Sansa E280 MP3 Player
Refresh database?Need Serious HELP!
Have you removed the battery, wait then reinstall it to try to reset it? Been the Sansa website and their FAQ or tech support?
Mar 04, 2008 | SanDisk Sansa e250 MP3 Player
Very weird...
'Refresh Database' doesn't mean everything is erased. It only means it's writing the progress that you made, onto the computer. It stays on 'Refresh Database' for about maybe 5-10 minutes. It refreshes its database every time you disconnect your MP3 player from the computer. What it does when you disconnect it from the computer is it saves any unsaved changes made to it and overwrites the memory or data.
Oct 28, 2007 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
