Question about Elna Sewing Machines
Why won't my Elna 62C won operate with the cams nor will it do a zig zag stitch.
My Elna Supermatic 62C won't zig zag. Why?
ray gallant
    Top Expert:
  • Elna Master
  • 69,239 Answers
Watch the video here
Posted on Apr 08, 2015
Chris Wetmore
    New Friend:
  • 190 Answers
It is likely that your elna graph gear is broken.
remove thread from machine and open door to where you put cams in. Step on pedal and run at full speed. It the mechanism where the cams go spinning? If not the gear is broken.
Posted on Aug 22, 2014
  • Paul
    Paul Mar 18, 2015
    Chris, I'm hoping you'll see this comment. Our Elna SU (1973) appears to have developed the same problem today - the mechanism where the cams go is not spinning but if I give it a slight turn by hand, it turns a full circle before stopping again. Seems like a cog is broken off a gear. Is this the graph gear and is it the same as the cam gear or are they totally different. The machine won't zig-zag or do buttonholes - it only sews in straight lines. Many thanks, Paul
  • Chris Wetmore Apr 08, 2015
    The same elna graph gear as above
5 Related Answers
night71
Lyle Siemens
  • 328 Answers
SOURCE: upside down stitching
Sounds like the needle alignment is out.
This website has some instructions on how to properly set it up and also has manuals too.
http://welcome.solutions.brother.com/bsc/public/us/ca/en/faq/faq_list.html?reg=us&c=ca&lang=en&prod=hf_cs8072eus&Cat=53
Posted on Nov 01, 2007
bargainbox
Hassy
  • 1388 Answers
SOURCE: Elna Carina Zig'Zag Stitch Issue
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Bargain Box
Posted on Feb 01, 2008
SewTechWayne
SewTechWayne
  • 186 Answers
SOURCE: zig zag won't work
Make sure stitch width slider is not set to zero. If not then you either have a bind in the needle bar pivot or an electrical problem (bad stepper motor or bad circuit board).
I can't remember if this machine has a twin needle lock out, if so turn it off.
Good Luck!
Posted on Feb 01, 2009
Anonymous
SOURCE: have a 1970's elna su supermatic but cams don't work
There are two types of discs - single and double.
For the thinner single discs do as follows:
1.Turn stitch width knob to "0"
2. Turn stitch length knob to "0"
3. Insert the single disc
4. Turn the top selector to "A"
5. Make sure the needle selector is in the centered position.
6. You may now choose any stitch length or width you wish. I usually try "3" for the width and 1/2 for the length to start.
For the thicker double discs do as follows:
3. Insert the double disc
6. You may now choose any stitch width.
7. The stitch length must be put on "A" - this is the difference between the single and double discs!
I hope this helps!
Posted on Apr 09, 2009
Anonymous
SOURCE: Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
Posted on May 24, 2009
ELNA 62c, AM UNABLE TO ZIGZAG WITH IT. WHAT AM I DOING WRONG? DOES THE ZIGZAG HAVE ISSUES & WEAR OUT? IT TRIES TO START TO MOVE THE NEEDLE OVER BUT IT DOESN'T DO THE ZIG ZAG STITCH.HOW CAN I FIX THIS?
From the info I found, this appears to be an older mechanical machine. If so, most likely it is seizing due to lack of frequent oiling and cleaning. AVOID using the machine until you get the issue resolved as it could damage the motor. The following may be helpful in getting your machine back to working again. Lack of oil can affect many different moving parts in the machine. It just happens that it has first appeared with the zig-zag capability of your machine. Apparently, manufacturers did not anticipate these machines would last so long--they assumed the machines would be periodically maintained by a professional technician who would regularly oil. As a result, many of these great machines have been sidelined simply for lack of oil... but they can be brought back to life.
Wheel on right side that controls the needle up and down is very tight...
http://zengrain.com/elna-elnasuper-62c-sewing-machine-manual
May 09, 2017 | Elna Sewing Machines
Elna machine puckers silk on zig zag stitching, Elna 2007
Yes, because a zig zag stitch is creating a wide stitch and the tension on the thread is going to pull the fabric within the seam together, you can't seam thin fabric with a wide zig zag. It will "tunnel together". If you are using this stitch to neaten a raw edge, then try using the serpentine or three step zig zag where the needle pierces the fabric 3 times in each leg of the zig zag, this will give better results.
Jul 07, 2015 | Elna Sewing Machines
Set zig zag stitch on Elna Elina 40
I have looked but can't see a manual, but looks like push button stitch selection on front of machine, often it will be same as straight stitch, but need to take stitch width from 0 to 4
Feb 27, 2015 | Elna Sewing Machines
How do a i do a zig zag stitch
Simply turn the dial to get the zig zag setting. Manual in the linky
http://www.janomeflyer.com/pdf/Elna%20eXplore%20320%20manual.pdf
Oct 07, 2014 | Elna Sewing Machines
Can you find a user manual for an elna supermatic V/NV/62?
Lots of places have them
Google
Elna 62C Sewing machine manual
Jul 18, 2014 | Elna Sewing Machines
How do I turn the selection dial to zigzag on my Elna Super
I've got a Supermatic manual but I think maybe you mean the earlier model perhaps. On the supermatic you set the stitch width to 2 and stitch lenth to 2+ for a zig zag. In this image, the stitch width selector is marked "3" and the stitch length selector is marked "4".
I've got a feeling that on the earlier model you may need to use a zig zag (single) disc in the Elnagraph to get the needle swing function.
As you probably don't have a manual, you may want to join the Yahoo group called Elna Heirlooms as the members there share info on these vintage machines, and some manuals are there.
Go to www.yahoo.com, sign up, then go to "Groups" and search for "elna Heirlooms". You will need to ask the moderator to join the group but once accepted, you'll find lots of helpful information, check out "Files" for shared documents.
Hope this is of help to you.
Nov 06, 2011 | Elna 2007 Mechanical Sewing Machine
Instruction book
Nice vintage machine, you can buy a copy of the instruction manual here
http://www.sewingpartsonline.com/instruction-manual-elna-62-64-72-74.aspx
or try ebay, some vendors sell manual copies on CD.
You may like to join the Yahoo group called Elna Heirlooms too, lots of owners of these Swiss made machines there who share knowledge there.
Dec 04, 2008 | Elna Heirloom Edition 6005
Sewing Machines Logo
541 people viewed this question
Top Elna Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Nick Olsen
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
