Took vehicle to emission station and they suggested that I have should have technician tell me how to complete a drive cycle that is intended to make my vehicle's obd system ready
OBD is an acronym for "On-Board Diagnostics", standardized as OBDII (OBD 2) in 1997. Through OBDII, the car's computer monitors all important subsystems and can report failure codes for any of those subsystems when something goes wrong.
You didn't drive very far to that emission station, did you? If the engine and transmission aren't fully warmed up when you get there, they won't be able to get reliable status codes from the computer... so you should be sure that the car is fully warmed up from driving before you arrive to be tested.
A service technician will
turn off the dashboard "check engine" light after most repairs. This
resets the vehicle's emission system components to "not ready". The
status remains "not ready" until the vehicle's computer has had adequate
time to review the repaired component. This happens after the vehicle
is driven for a period of time established by the manufacturer.
If the vehicle's emissions system status is "not ready" when it is presented at the E-Check station during the initial test cycle,
a tailpipe emissions test may be conducted. If the vehicle is
transferred to another test type, the vehicle must remain on the
different test track until the vehicle passes the emissions test or
receives a waiver. For example, if the vehicle undergoes an OBD II test
and fails, it cannot be downgraded to a tailpipe test on a re-test; the
vehicle must pass the OBD II test.
For initial and subsequent tests, if a dashboard light is on when the vehicle is presented at the E-Check station, the vehicle will fail the test.
How can the vehicle status be made ready?
When a vehicle is driven through its normal drive cycle, the computer reviews the emission control
system and if the vehicle was properly repaired, the system resets itself to ready. A normal drive
cycle includes operation at both cruising speeds and in stop-and-go traffic for up to a couple
weeks. This process should be followed before bringing the vehicle in to be tested.
