Question about Yakima RocketBox
I have a 2000's era Yakima Rocketbox and a 2014 Chrysler Town and Country. The bars factory roof are to close for the rocketbox. Does anyone know of a way to adjust the rack or the rocket box?
Are there any adapters to enable me to attach the rocketbox to my Chrysler Town and Country. The problem is that the distance between the bars on the factory installed roof rack are to wide for the rocketbox.
Posted by John Cornelius on
2 Related Answers
bunnydawg
Roberta Smith
  • 5158 Answers
SOURCE: cracked cargo box (yakima)
good old duct tape... i would get some silicone caulking and run beads along the cracks in the box to seal the water out. not sure what colour that is but the caulking comes in many colours as well as clear.
Robert
please take a moment to rate this solution.. thanks
Posted on Feb 05, 2009
Coachphil
Coachphil
  • 347 Answers
SOURCE: I have two different SKS cores. One for my
You have to replace the SKS cores you don't want with mates to the ones you do want.
I would suggest replacing the snowboard cores with ones that are the same # as your towers since then you are only replacing 2 cores instead of 4 and it is cheaper.
The key should have a number on it that tells you what core it goes too. You can either contact yakima and get the exact cores you need or go into your local dealer and see if they have them in stock or can order for you.
Posted on Dec 30, 2010
I need to replace the intake air temp sensor in my 2000 Chrysler Town and Country
WHY? MAP SENSOR/ IDLE/ SPEED SENSOR
DO YOU HAVE A CHECK ENGINE LIGHT?
ATTACHED TO INTAKE MANIFOLD
Sep 22, 2013 | 2000 Chrysler Town & Country
2001 chrysler town and country limiteds blower motor wont shut off why?
if the blower wont shut off its be cause of one reason, replace the heater control
Sep 04, 2013 | Tow Bar Base Plate Chrysler Town & Country...
Cabin Air Filter replacement. Where is it located on a 2006 Chrysler Town and Country?
there is a panel just above passengers feet, take panel off and filter should slide out (down) you will see how panel is attached (no bolts)
Aug 03, 2011 | 2006 Chrysler Town & Country
My 2001 Chrysler Town and Country won't accept my cassette adapter. It is Brand new and it goes in and then ejects.
I have same issue on a 2000 T&C. Was working fine for years.
Now, each tape reverses and ejects.
Any responses on this?
May 08, 2011 | 2001 Chrysler Town & Country
Does an 02 town and country chrysler have struts or shocks in the front?
not familiar with chrysler bein an aussie an all but i would assume they are struts.to check turn steering to full lock and look behind wheel. a shockie will be bolted at top and bottom with a single bolt for each end. a strut is a complete unit
Feb 27, 2010 | 2002 Chrysler Town & Country
I need to get to the back door motor
your plastic molding is probably held on by anchors that simply are attached to the trim and can be popped off with a small flat bar ve careful though they break easily if too much force is used
Jan 09, 2009 | 2004 Chrysler Town & Country
Yakima RocketBox Logo
102 people viewed this question
Top Yakima Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you a Yakima Boating Expert? Answer questions, earn points and help others
