Question about Brother Industries, Ltd Brother Sewing Machine
Brother exedra E-40 why it alway get tangle and brake the threat?
meisheng Liu
    New Friend:
Power open the needle began to work
Posted on Nov 08, 2015
Debbie
  • Brother Indu... Master
  • 1,860 Answers
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Posted on Aug 07, 2014
1helpful
I have a Brother Exedra DB2-B737-403 industrial machine. How do I wind the bobbin?
It's an industrial machine. You use a stand-alone bobbin winder.
https://www.amazon.com/bobbin-winder/s?k=bobbin+winder
Look, no bobbin winder.
https://www.ebay.com/itm/264059721244
From my EXTENSIVE research on your behalf, it was an optional attachment.
Contact Us ' Brother Solutions Centerhttps://support.brother.com > contacttop
Others. Support & Downloads. Contact Us ... Before contacting Brother, we recommend that you refer to the FAQs available for your Brother product. Submit.
What size and type needle does the exedra E-40 need to sew leather?
Any local sewing machine sales and repair can get you what you need.
Need manual for brother exedra E-40 industrial sewing machine
google make/manual then will ask for model and you can print or download for free
I have the lockstitch brother exedra and the lockstitch has stopped workingDo you know how I can fix it
it probably needs to be checked by a sewingmachine tech to see if a gear is damaged or broken
Need manual for Brother Exedra E-40 sewing machine
brother EXEDRA E-40 sewing machine power switch is turned slowly work up and down a single needle immediately
2answers
Machine is showingE6
The motor locked up because the thread is tangled. Remove the tangled thread before continuing the operation.Clean the bobbin case to remove the tangled thread. After cleaning the bobbin case, insert the bobbin case properly. If the needle is bent or broken, replace the needle.Then, thread the upper thread properly, and continue the operation.
brother sewing machine
3helpful
Looking for an Brother Exedra 11 manual please
There are free manuals to download at Brother-usa.com. They use a combination of letters and numbers to identify the machines.
Search industrial sewing machines to see if there is a manual that best supports your machine.
Tangled thread under metal plate
-The bobbin is too lose. Tight the adjustment screw on the bobbin case a little more and test, keep doing until it's good.
-Or possibly the upper threat is too lose so it won't pulls the bottom up as well.
-Check it out and adjust it.
Good luck
Mai
Open Questions:
See all Brother Industries, Ltd Brother Sewing Machine Questions
Brother Industries, Ltd Brother Sewing Machine Logo
Top Brother Industries, Ltd Sewing Machines Experts
tina gallow
Are you a Brother Industries, Ltd Sewing Machine Expert? Answer questions, earn points and help others
