Sony STR-DE845 Receiver Logo
A
Anonymous Posted on Aug 04, 2014
Sony Receiver No Sound
I have no sound coming from my speakers at all. I tried changing the input from CD/Phono/etc. but nothing produces sound. The fuses are not blown, and the speakers are not shorting. How would I fix this?
5 Related Answers
Hilum Audio
  • Posted on Aug 17, 2007
SOURCE: No output on main speakers
I have experienced a similar problem with my Sony STR-GX57ES and took it to a certified tech only to find it needed the power supply replaced. I opted to hunt down a compatible power supply but have been unsucessful thus far. That being said I picked up an STR-D665 for next to nothing and found the power supplies to be quite different (you would hope so any, with the ES meaning Elivated Standard and all) but with the D665 working flawlessly I'd rather have something working than nothing. Good luck!
Anonymous
  • 3 Answers
  • Posted on Jan 27, 2008
SOURCE: Sony STR-DA5300ES Audio Problem
I am posting this to try and get everyones audio problem for this receiver fixed. If you only connected the HDMI cable to the 510, you will not get sound. This receiver passes through HDMI only, no processing of audio. You must either connect a fiber optic or digital coax to the 510 for that respective HDMI input from the BD player, the DVD HDMI only accepts digital coax, and the Video2 HDMI only accepts fiber optic. If you BD player does not have digital coax out for audio, you must move the connection to Video2 HDMI and connect fiber optic to the Video2 fiber input. Sony butchered the whole purpose of HDMI with this receiver. Hope this heps you. By the way, it is hardware, no firmware update will correct this.
Fwayne
Rick Davis
  • 97 Answers
  • Posted on Jan 05, 2009
SOURCE: No Video or Audio on HDMI on Sony STR-DG800
I dont have the exact model you do, but on my sony receiver I have to enter the setup menu and define where the input is for the device I am using. For example I have to tell the receiver to use the optical audio input instead of the RCA Stereo. Otherwise its on default.
Also, you do know this model of reciever offers only pass-through audio on HDMI? that means no surround sound!!! Thats really silly but thats the specs for this model. To get surround you'll have to use optical. otherwise , with HDMI through this sony you are adding an extra component to tyour system with no benefit other than maybe power amplification.
Anonymous
  • 814 Answers
  • Posted on May 18, 2009
SOURCE: Sony str-de675 receiver has no sound at speakers when turned on.
This unit is having a problem with the preamplifier and power amplifier section. The reason to suspect this is that you can still hear sound, this is not likely if you ahd a failure in the power supply section. The unit may have had a failure in the amplifier areas of these sections, These are the signal amplifier sections that increase the power of the signal to drive the sound in the speakers .The Unit is probably in the protection mode reducing all power to prevent further damage to the rest of the receiver. You can go to the www.sony.com website support section and look in the frequently asked question and troubleshooting sections for problems like yours and see if they have any answers. On this website you can also find customer support. Ask them questions about the problem and see if they have any solutions.If all this fails to answer you problem, you can try opening the unit and looking for the problem yourself. Only work on the unit with it unpluged from the power source. Take off the top cover and look for any damaged areas, on the pc boards.They would be brown areas from excessive heat due to component overheating and possible failure.Look for capacitors that may have gone bad, they will be bulging from the top and bottom and may be leaking material from inside of them. Any component like this needs to be replaced. You may find burnt resistors and other failed components that will require a digital voltmeter to test.If you have expperience with this type of repair you might be able to isolate the problem and replace the parts. This may require the help of service information due to the complexity of the receiver's operations. Try to get a schematic or service manual from the web or a repair shop. This will have all the parts and a diagram of the all the different sections of the receiver. Usuall there is a power supply section, a tuner section, a preamplifier section, and a amplifier section. There also could be a equalizer section and other sections according the functions of the receiver. The failure most likely has occured in the preamplifier section or amplifier section. The problem in the preamplifier section could be a signal diode failure or a signal amplifier failure. in the amplifier section the problem could be in the output power devices which may be transistors or ic's depending on the type of output amplifier use in the unit. Usually not that hard to find with good service information and test eauipment.You may want to take this to a school that teaches electronic servicing and see if they will work on the unit for you for the cost of parts and a small labor fee. Call them first and see if they can help you out. I hope this helps you with your problem.
harley07825
  • 23 Answers
  • Posted on Jul 17, 2009
SOURCE: Sony STR-SE501 makes popping sound/cuts off
just repaired my se 501 poor solder conections on blue rleays by speaker jacks,also blown center speaker seems there are 2 in it one blew and so did cpacitor running now just hooked up one in center speaker sonds great also stay at 8 ohms setting
No sounds coming from my Sony PS-LX250H
you will an amp . this unit is supposed to a preamp., making it line level.
The Sony PS-LX250H's built-in phono preamp allows you to use the turntable with any receiver, HTIB, or computer sound card by plugging the turntable's cables into any line-level input, such as auxiliary or VCR. If your receiver does have a dedicated phono input, we recommend using it instead of the turntable's internal phono preamp (which can be turned off). Chances are, the turntable will sound better that way.
https://www.cnet.com/reviews/sony-ps-lx250h-fully-automatic-turntable-review/
Turntable hookup to AUX or CD (no Phono input) only producing very weak sound, even at full volume
You are doing nothing wrong at all. It's just that as you say it has no phono input. Which means the sockets you have will NOT amplify the signal. So you need to buy a magnetic cartridge pre-amp and once connected to the aux the weak signal will be at the normal level.
How can i connect my laptop to a db790 amplifier?
All you need is a 3.5mm Stereo Mini jack to two RCA jacks. Connect this to the line or speaker out of the laptop into anything but the phono input on your sony. The phono input will be over driven and sound bad and possibly damage something in the system. Try using any other unused device input on the receiver.
I recently bought this turntable used. I am trying to connect it to a Sony receiver with a phono input, but no sound comes out when connected. Does this turntable require a pre-amp or something?
If the unspecified Sony has a "PHONO" input you should be good to go. What model?
"PHONO" is the only designated connection on an audio device that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify and frequency-correct the tiny current produced by a Phono cartridge. Look up RIAA equalization.
If your unit doesn't have a PHONO connection AND your TT doesn't have a self-contained preamp you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some...
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
http://shop.ebay.com/i.html?_from=R40&_trksid=p3984.m570.l1313&_nkw=phono+preamp&_sacat=See-All-Categories
I hooked up the ion LP Dock to an analogue amplifier (which is hooked up to my LCD tv and outputs the sound through some bookshelf speakers) via the Phono input connections as per the instruction manual...
"PHONO" is the only designated connection on a receiver that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
BUT, modern turntables like your come with their own preamplifiers, so they MUST be connected to a garden variety Line Level input like AUX (anything BUT Phono or it will overload).
http://www.needledoctor.com/Ion-LP-Dock-Turntable?sc=7&category=16189
"LP DOCK also has a line-level output for connecting to any home stereo with an AUX input"
As far as WHY your amplifier isn't making da music, that could be whole 'nother problem.
We'd need more details about it and the speakers to go there.
1helpful
I have a Sony CDP-CX355 300 CD Player and old Technics SA-5060 receiver and two new Insignia NS-B2111 bookshelf speakers, with old but solid speaker wires. When playing the CD player, loaded with symphonic...
Don't run anything but a TURNTABLE through Phono. That's the only labeled input that's literal. Use any other Line Level input for the CD.
If you don't have anything connected to the Tape loop, use the Tape In connectors.
4helpful
Sherwood RX-5502 receiver - get no sound.. checked polarity - OK... replaced speaker wire - OK... checked speakers on another device - OK.... tried phono and tuner and cd player - no sound with any........
After doing all this troubleshooting on your receiver, Check if master volume on the surround levels are too low. Adjust master and surround level.
There may aIso incorrect selection of the input source. Select the correct input source.
If after doing this the problem still continue, it means the sound ic in the receiver is damage. the sound ic brings out the sounds from the receiver. You will have to open the receiver to locate the sound ic in the receiver and use the multimeter to read capacitors and change the damage ones.
Thanks for using Fixya.
1helpful
I have a phono preamp hooked up to my Yamaha receiver for a turntable. My tall speaker tipped over and knicked the receiver and now my turntable will not produce any sound. Could this have blown the phon...
Let's figure out which hardware is failing. Connect the phono preamp to the CD or tuner input to see if it works there. It should. If it does, your receiver is at fault. Did the front panel controls get damaged?
How did the turntable fare in this accident? As a basic test of its ability to produce sound, hook it directly to the CD input and raise the volume slowly while playing an LP. If it's alive you'll hear a very weak, tinny sound, but I assume you know that or you wouldn't have a phono preamp in the first place and would probably be asking why the TT sounds so poor. :-)
Connecting pc audio to str-de898
You're close. PHONO is NEVER the place to send Line Level signals. It is for the small output produced by a phono cartridge only. Google RIAA equalization to see why it sounds so bad when connected that way.
That you get sound through Phono at least proves your PC is producing an output. Now we have to figure out why your RECEIVER doesn't sense the program where it should be connected.
If you have another analog audio source that works on the receiver, temporarily connect the PC audio there to see how it sounds. Then think about why it doesn't work in MD/TAPE, SA-CD/CD, TV/SAT, DVD, or either Video IN. Any of those should work.
2answers
Can't get B Speakers to work
Use the remote and switch it to be in the sub mode (top right corner of remote) It is here (in the sub mode) that you can change volume and inputs.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
