Question about Moultrie M80XD Mini Infrared Digital Trail Cameras 2 4GB Memory Ca
Camera won't take pictures by motion - Moultrie M80XD Mini Infrared Digital Trail Cameras 2 4GB Memory Ca
Charlie Tucker
    New Friend:
  • 24 Answers
Moultree doesn't seem interested in supporting their junk. Buy a different camera that isn't from Moultree.
Posted on Aug 17, 2014
Picture comes out blurry
There are three main reasons for blurry pictures.
Pictures may come out blurry if they're not focused properly. If some objects are sharp and others are not, this may indicate focusing on the wrong subject. This is usually not a major problem with compact point&shoot cameras since they have such a wide field of focus that almost everything will be in focus anyway.
Subject motion. If moving objects blur while stationary objects remain sharp then the shutter speed is too slow to freeze the motion. Try switching to the sports mode, and/or add more light.
Camera motion. This is the most common cause. Set your camera on a table or other stable surface and use the self-timer to take a picture. Take another one while holding the camera. Compare the two on your computer.
Feb 22, 2012 | Canon PowerShot SD870 IS Digital Camera
How do I set the resolution on my Canon SD850?
The instructions for changing the resolution are on page 30 of the manual.
If the pictures are fuzzy, increasing the resolution won't help. The most likely causes of fuzzy pictures are as follows
1) Focus. Check to make sure the focus is on the subject. If something else in the picture is sharp while others are not, then the camera may have focused on the wrong subject.
2) Subject motion. If moving objects are fuzzier than stationary objects then you need to use a faster shutter speed (or flash).
3) Camera motion. Just because the camera is on a tripod doesn't mean it doesn't move. One philosophy says that if a tripod is light enough to be carried then it's not sturdy enough. For a compact camera like the SD850 that likely isn't the problem. However, you can still shake the camera when you press the shutter release button. Try setting the self-timer. This allows time for the vibrations to die down before snapping the picture.
In your particular case, I think we can assume that the subject isn't moving, so #2 doesn't apply. To assure proper focus, make sure the painting is flat and perpendicular to the lens axis. If the painting is tilted relative to the camera, then different parts of it will be at different distances and the camera won't be able to keep all of it in focus.
Also, make sure the front of the lens is clean.
Feb 03, 2012 | Canon PowerShot SD850 IS Digital Camera
Some of my pictures are blurry using a cannon rebel 3. how can i fix this problem?
There are several possible causes for blurry pictures.
1) Camera motion. If everything is blurry, it's most likely because the camera moved while the picture was being taken. Make sure your shutter speed is fast enough if you're handholding the camera (longer lenses require faster shutter speed). Alternatively, put your camera on a stable surface, such as a tripod or a tabletop.
2) Subject motion. If the subject is blurry but the background is sharper, then the subject may have moved while the picture was being taken. Use a faster shutter speed. Raise the ISO if needed. There are limits, of course. If you're trying to photograph a fast-moving object in the dark, you probably won't be able to.
3) Improper focus. If the subject is blurry but something else in the picture is sharp, then the camera probably focused on the wrong object. Move the focus selector to the subject you want in focus. Alternatively, center the viewfinder on the subject, press the shutter button halfway to lock focus, then reframe and shoot.
Without any more specific information as to what and how your pictures are blurry, I'm afraid the above is all I can give you.
Jan 13, 2012 | Canon Cameras
When i was taking picture the lens of my camera ( sony dsc-w120) become blurd. why'?
The cameras capacity to capture motion pictures is disimpressionful. Usually cameras have feature functionalities either as still picture shoot or motion video recorder devices. Cameras may have any once of the mentioned features or both as complementary for videographic requriements. Inspecte the camera for capacity to capture motion picturee. Usually, the lense capacity with pixel capacities are indication of extensive capabilities. An impressionful camera producign disintergral result requries adjusting the lense or pixles buttons prior to photo shut. Also, cameras that least have the pixel capacity requires photo shoots at still motion or at calm climate least onbracting activities. Capture pictures at areas that least have movement caused by human interfernce or windy or suny blurs. Also, capture pictures maybe retored of blurry filming from computer photo video editor programs. Capture the picture or videos to be loaaded on to a computer that allows editting to achieve desired interfaces.
Feb 07, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
I have my web cam all set up and the camera flashes for a short time and then goes off. It shows my picture for a short time and then goes off can you help please
Usually the computer has recognised the connection of an external device. A camera software on the computer should allow to capture store and edit photos or videos. Depending on the type of camera, like with digital cameras, only still images are acquirabel and not videos or motion pictures. Refer to the capabilities of the type of camera either as web cam, digital still camera, or simply incapable of motion picture features.
Jan 22, 2011 | Microsoft LifeCam VX-1000 Webcam
Camera does not pick up motion and take pictures all the time, and at night some pictures are all black.
Need more info about the camera. Is this a Digital motion sensing trail camera. . . what brand?
Oct 06, 2010 | Cameras
Why are my pictures coming out blurry?
Pictures may come out blurry if they're not focused properly. If some objects are sharp and others are not, this may indicate focusing on the wrong subject. This is usually not a major problem with compact point&shoot cameras since they have such a wide field of focus that almost everything will be in focus anyway. However, make sure the macro/far switch is set to the appropriate position for your picture.
Jun 12, 2010 | Vivitar ViviCam 8025 Digital Camera
Date stamp function on Sony Cybershot S750 camera
This Camera doesn't have the feature to superimpose the date on the pictures. By using the supplied Picture Motion Browser Software, you can print or save the pictures with date.
Refer the following link to use the supplied Picture Motion Browser Software to print or save the pictures with date.
http://support.d-imaging.sony.co.jp/www/disoft/int/pmb/feature/edit/attach_date.html
Feb 09, 2010 | Sony Cyber-shot DSC-S750 Digital Camera
Date stamp on sony DSC H3 camera - How
Refer the following link.
Lost the Original Software Installation Disc? Use the Picture Motion Browser Software Download.
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4598&mdl=DSCH3
Feb 04, 2010 | Sony Cyber-shot DSC-H2 Digital Camera
THE LCD SCREEN IS BLACK AND I CANT TAKE A PICTURE. BUT I CAN STILL VIEW MY PICS. THE CAMERA GOES THRU ALL THE MOTIONS LIKE IT IS TAKING A PICTURE BUT IT IS JUST COMING UP BLACK.
The LCD screen is black and I can't tace picture. But I can still view my pics. The camera goes thru all the motions like it is taking a picture but it is just coming up black.
Aug 31, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Moultrie M80XD Mini Infrared Digital Trail Cameras 2 4GB Memory Ca Logo
385 people viewed this question
Top Moultrie Video Cameras Experts
Harrie
Andrew Taylor
Andrew Taylor
Are you a Moultrie Video Camera Expert? Answer questions, earn points and help others
