Question about Samsung SCX-4216F All-In-One Laser Printer
Airprint from a Iphone 5s to samsung scx-4216f connected via usb to Asus rt-n66u router possible?
Can I airprint to this printer with iphone 5s
5 Related Answers
HEMANT GROVER
  • 171 Answers
SOURCE: Can a Samsung SCX-4216F scan to pdf format?
In windows, Scx 4216f comes with Samrthru3 which does not come with pdf scan option , however you can use the newer verasion of smarthru4 which is available with scx4100/scx4521f .
All you need to do is choose Scx4216f as the device in smarthru window. and you will be able to scan in PDF format.
Will be quite simple.
Happy Scanning
Omnipresent
Posted on Oct 26, 2007
nitinbabbar
NITIN BABBAR
  • 55 Answers
SOURCE: Samsung scx-4216f
try this,
Fehl.ATM-fixing. in this case the toner cartridge is not properly used in the device. Take the cartridge out of the device and put them, as described in the instructions. or in SCX 4216 when the count is not automatically reset, you can count manually by the following key combination reset:
Menü Menu
thnx N
Posted on Jan 31, 2008
Anonymous
SOURCE: SAMSUNG SCX 4216F NO-SCANNER
Eureka!
http://www.nodevice.com/driver/company/Samsung.html
scanner now works with both ABBYY and SMARTHRU without crashing ...
chmv
Posted on Sep 12, 2008
Anonymous
SOURCE: requiring scanner software for samsung SCX-4216F printer
Dear Sir,
I have Samsung SCX-4216 printer. Printing, Xerox & Fax working is OK, but scan facility is not working because i missed the original software. please give me  a solution for get the original software or scan drivers.
With Regards
Mohan
Posted on Jan 24, 2009
Anonymous
  • 3 Answers
SOURCE: Problems with Samsung SCX-4216F All-In-One Laser Printer?
SCX-4216F could receive fax, but didn't print out faxes. Can anybody help me with this?
Posted on Mar 11, 2009
Where would I find my key code on my router
If you have set up the router's wifi network before, you probably put in a key code. You can change the code by logging into the router with a wired connection. (With a browser go to 192.168.1.1 and use the default user and password (if you haven't changed any of these). It's in the manual: http://dlcdnet.asus.com/pub/ASUS/wireless/RT-N66U_B1/E7018_RT_N66U_B1_Manual.zip for the English copy. Extract the PDF from the file and see page 17. Other versions of the manual are available here: http://www.asus.com/Networking/RTN66U/HelpDesk_Manual/ . ) If you try to use a computer that is already accessing the router via the wireless network, you'll lose the connection when you apply the key code change.
If you have changed the administrative user name and password, you may need to reset the router to factory settings. Press the recessed Reset button with a ball point pen or straightened paperclip. Hold the button down for about 5 minutes.
There wasn't a key code built into the unit for the wi-fi network. I hope this helps.
Jul 19, 2014 | ASUS Rt-n66u Dual-band Wireless-n900...
Where would I find the key code on my ASUS RT-N66 wireless router?
IF you are trying to set up your router, check your default gateway it should be 192.168.1.1. the default username and password to your router should be admin//admin
Not printing
Set the ip in the printer. Set the correct subnet mask and ip address in print server.
Apr 01, 2014 | ASUS RT-N66U Wireless Router/Printer...
Unable to print
Same answer to your previous post
AirPrint not working
there is a free App from Canon:
"Canon Easy-PhotoPrint" - try it airprint-not-working-50j4ioddfaeyronb2saotemk-4-0.jpg
Feb 12, 2013 | ASUS RT-N13U Wireless Router - 300 Mbps 1...
Can i connect a high gain antenna to any of your routers
Yes you can. They are yours and you have every right to connect what even antennae your heart desires.
Feb 06, 2013 | ASUS RT-N66U Wireless Router - IEEE...
Mar 03, 2009 | Samsung SCX-4216F All-In-One Laser Printer
Samsung SCX-4216F All-In-One Laser Printer Logo
74 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
