Question about Konica Minolta Bizhub 223 Copier
I forgot my Bizhub 223 administrator password
Can I also change it from the default number?
Adorjani Laszlo
  • Konica Minolta Master
  • 1,316 Answers
The factory admin password is 12345678.
Posted on Aug 05, 2014
walter jansz
    Scholar:
  • 177 Answers
The admin password is 12345678 yes you can change the password you will need to log into the tech rep mode once in tech rep mode you need to press the following buttons stop 0, then the C button
once this is done you then select admin password and change it
3 Related Answers
xeerie
Zaheer Ahmed
  • 347 Answers
SOURCE: Does Konica Minolta bizhub c250 All-in-One Laser
yes, it have a default administrator password which is 8 times 0 (zero).if this does not work then try 12345678. best of luck.
Posted on Nov 03, 2010
Visualpro
SOURCE: Konica Bizhub Password Reset
You can try the default admin password which is 12345678
Posted on Apr 17, 2009
just me
  • 60 Answers
SOURCE: I have one Konica Minolta
There is no procedure to restore the admin password. It is possible to reset and enter a new password, and for that you will need a technician to make the adjustments on SERVICE MODE (stop,0,C).
Posted on Feb 14, 2011
I forgot the password for sharp AR 5620N
Dear moses Adongo,
Greeting!
Was the administrator password changed from the factory default setting?
if yes!!
Contact your dealer or nearest SHARP Service Department.
For the factory default administrator password, see "TO THE ADMINISTRATOR OF THE MACHINE" in Quick Start Guide. After changing the password, take special care to remember it.
May 23, 2018 | Sharp Office Equipment & Supplies
Administrator log in
1-Press "Utility/Counter button from control panel.
2-Press "Administrator settings" from Touch screen LCD menu,
3-Enter "Admin Password" which is 12345678.
4-After entering the above password, press "ENTER" or "END" button, (appeared on top right side of menu).
5-After pressing the end or enter button you will be in administrator mode.
Now, if you are asking about the Administrator password, then the password is "12345678" This is the default administrator password of Konica Minolta bizhub MFPs and Photocopiers.
For any other queries, feel free to ask any time.
Jan 31, 2013 | Konica Minolta Bizhub C300 All-In-One...
I have one Konica Minolta bizhub c250, unfortunately I forgot the administrator password can I reset it to system default.
Jan 27, 2011 | Konica Minolta bizhub C250 All-In-One...
Does Konica Minolta bizhub c250 All-in-One Laser printer have default password to go in Administrator mode?
Oct 08, 2010 | Konica Minolta bizhub C250 All-In-One...
I have forgotten the administrator password for my Konica minolta bizhub 252 I have not changed it do you know the origional default password
It is either 00000000 or 12345678
These are the 2 possible default passwords that work on Bizhub series machines. One of these will work as long as it has not been changed.
Good Luck and Thnak You for using Fixya.
Sep 12, 2010 | Office Equipment & Supplies
Konica Minolta Admin Password
Try 12345678.  That worked for me for my Bizhub C250.
Mar 18, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Bizhub c350 default password is 12345678 give that a try
Mar 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Biz Hub 250 Setting up Scan Button & Resetting password
If you login as administrator via the browser you can edit the scan button settings, (administrator code 12345678)
Feb 16, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Trying to get the administrator password on my bizhub 350
The default is "12345678" If it has been changed then you are outa luck eh.
Aug 05, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Bizhub 223 Copier Logo
3,648 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
