Question about Garmin nuvi GPS
Can not put an address in garmin nuvi
It says map data not available
Paul Ragas
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
Similar problem was cured by reformatting the Mini SD card that holds the map data. I had the same problem this week with my Garmin Nuvi 265. After doing an update I received the "No Data Available" message when trying to use my GPS. After trying three days of so-called fixes I remembered that, at least in my case, the map is stored on a Mini SD card. I pulled the card from my Nuvi and popped it into the computer to see what's on there. There are 4 or 5 files associated with the map. I deleted the files and reformatted the Mini SD card using the FAT32 setting. I reinistalled the card into my GPS. Prior to connecting the GPS to my PC, I uploaded the latest version of Garmin Express. Once that was loaded I reconnected the GPS and had to re-register the unit. Once that was done the software told me that there was a new update. I ran the update. Lo and behold . . . after about 25 minutes the map was successfully loaded to my Nuvi and it was working as it should.
Posted on Apr 01, 2016
Kenny Rasmussen
    Habit-Forming:
  • Garmin Expert
  • 184 Answers
Try running an update with Garmin Express, let it sit for 30 Min after it says it is done, then check again
otherwise you may have jsut installed a smaller region ,... again Garmin express could help.
Posted on Aug 05, 2014
5 Related Answers
Anonymous
  • 298 Answers
SOURCE: Garmin Nuvi 750 GPS
Have you tried this?
You can try this step that I found. If you tried loading other mapas try this.
You will need to erase a file from the units memory. Connect your GPS system to your computer; go to start then ‘My Computer’, and double click on your device file (mass storage system), there you will see a folder named ‘Garmin’.
In this folder are several different files, look for file named gmapsupp.img. Right hand click on this file and delete as this file is causing the maps to lock.
Posted on Aug 03, 2008
Anonymous
  • 2920 Answers
SOURCE: garmin nuvi 660 lost map data
take it back to the store you got if from and get a tom tom
Posted on Aug 25, 2008
sharcnet
SHARCNET-USA
  • 2130 Answers
SOURCE: "No Map Data Available" - Garmin Nuvi 350
This is because your map file has either been deleted or corrupted and needs to be replaced. Please see this link for more info. Too much info to copy & paste here:
http://www.sharc.net/nuvi_lost_map.htm
- Jim
Posted on Dec 13, 2008
Anonymous
SOURCE: Garmin Nuvi 205 keeps saying no maps available ???
This is easy. You have to run your software, select the maps tap and then transfer maps to the device. Chances are good you uploaded a 2009 map on top of the 2008 map. The updater doesn't delete maps.
Your unl file only has one key, you have two maps loaded. Simple go into the garmin directory and delete the map file and the mapsupp file. You can easily find them because they are greater than 500 mb.
Then run mapinstall (google for the file). This will install your most current map to the Nuvi. You are back in business.
Posted on Apr 12, 2009
Anonymous
  • 6 Answers
SOURCE: No map dat a available
who need to hook it up to the computer and download the maps back in to the Nuvi. Kinda reprograming if you will. the Garmins usually dont come with the usb cord to conect to the computer but you should be able to buy one. hook it up and download all the maps and you should be good to go. Oh by the way they have lots of cool fetures to download on the Garmin website cool cars and voices, although i prefere for mine not to talk. Good LUck
Posted on May 24, 2009
All of a sudden my garmin 3790LMT shows "no map data available" how to fix?
Is the SD card containing the map (and update) inside the Garmin device yet ?
I have had to recalculate my nuvi now when i touch "where to?" then touch "address" all it will do is tell me that "No Data Available" I can't put in a address or anything
Go into settings, select map, slect map info (window in middle of lower screen) & check that map inf box is ticked. then should be ok.
5helpful
3answers
- Jim
1helpful
Garmin nuvi 660 lost map data
1helpful
Hi Bruce. The same thing happened to me . I called customer support
1-800-800-1020 and they were able to link ino my computer, go through it and into my GPS. Hopefully this will work for you!!!
Tom
2answers
No data available mess
Did you try to perform a map upgrade to 2008? Turn on the Garmin and from the main menu touch the wrench, then press Map, then look for Map info.
GPS Logo
Top Garmin GPS Experts
Tom Chichester
Steve P
Steve P
Aron
Are you a Garmin GPS Expert? Answer questions, earn points and help others
