Have had the same problem with a Ryobi 1000w invertor generator. The problem that you are experiencing is the low level oil switch. To confirm if this is the problem disconnet the low level oil switch (Yellow or Orange wire). Try and start the generator now, it should start with the first little tug on the recoiler. Once it is running, reconect the low level oil switch and see what happens then. Either it will cut out, then you know it is the oil level switch or it will continue running and the problem will go away. Please ensure you manually check the oil level first before starting.
