Hi, it's Jeremy from Crucial Vacuum.
Attached is a copy of the user's manual for the Dirt Devil Featherlite Bagless Vacuum M085845. You can find a diagram of your vacuum on page 11 depicting where each part is located. The 2 hoses for your vacuum are listed as numbers 22 and 23.
http://dirtdevil.com/file/898/
You can purchase direct your replacement Dirt Devil parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dirt-devil.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
SOURCE: Dirt Devil Featherlite not picking up
It sounds like you have a blockage somewhere. The brush roll will still gather material, but if the suction is insufficient, it will spit it back out eventually. Take the bag out and check at the connection for blockage. When you are sure it's clear, put in a new bag and turn the machine on. The bag should inflate rapidly. If it does not, check elswhere for blockage.
SOURCE: Dynamite Dirt Devil Hose
I figured out how last night.
Take a screw driver and unscrew the screw on the top of hose and take the hose out and take a pen or something long enough with grip to get all of the junk out.
The circulation still isn't as strong though.
SOURCE: I have a dirt devil featherlite bagless vacuum;
there are 3 screws 2 on the left side behind the hose and 1 on the right back by the wheel.that will take the cover off.if you need to get into the bottom there is a screw on the bottom plate in the area where it looks like the belt travels.is the brush roller turning if not then your belt is probably broke.before you replace the belt clean off the motor shaft and get the old rubber off it otherwise the new belt won't last long.please leave feedback .be sure to clean your filter inside the dirt cup
SOURCE: hose gone on Dirt Devil DD2821 need replacement
http://www.espares.co.uk/part/vacuum-cleaners/dirt-devil/dd2821/p/1086/112/0/970655/478317/universal-flexible-clean-.html
This is the only hose "Dirt Devil" has listed for your model number.
SOURCE: I have a Dirt Devil Featherlite Bagless vacuum and
Try installing a new belt. also check for a clog in the hose.
