Question about OKI C Office Equipment & Supplies
I can't login to the admin page using the default login details which are root and aaaaaa I called OKI they said call one of our partners I've been quoted 105 pounds to reset the damned thing, I resent paying for something I should be able to do myself. Any ideas on resetting this device back to its factory settings.
1.Click on Start and go to control panel
2. Go to programs and then uninstall a program.
3. Find and uninstall your printer software.
4. Restart your system and install your printer.
5. Restart your system.
6. Live Happily ever after !
Posted on Aug 04, 2014
Apologies I can't edit this question the question concerns an OKI C562DN but if you read the question it's clear I'm looking to reset the hardware.
Try to login with username - root and password as Last 6 digits of Mac address. To know how to find mac address - assuming you use Windows : Click the Start button, select Run. Type CMD and click OK. A black Command prompt window will open. Type ipconfig /all and press Enter. ... Lots of information will be displayed, but what you need is in the Ethernet Adapter Local Area Connection section. Also, try to use username as admin instead of root
Hi, I can't login it's in the question, appreciate you are trying to help, but reading the question will give you a better understanding of my problem. Which is, I need to factory reset my OKI C562dn
SOURCE: my brother laser will not reset back to factory defaults
If you are using the printer in a LAN or Wireless LAN, you must assign to it an IP address compatible with your network. You do that by opening the Web admin interface of your router and assigning to the printer an address that is still free. Try 192.168.1.178 but that depends on the default gateway (192.168.1.1) that you defined for your router.
Posted on Aug 03, 2012
SOURCE: Reset to Default/Factory setting
press . (point) and # key Both simultaneously more than 10 sec this reset and reload the value default.
Posted on Oct 18, 2009
Feb 15, 2014 | Oki Electric Industry C9800 Printer
Dec 14, 2011 | D-Link DIR-615 Wireless Router
Aug 18, 2011 | Gateway Wireless-B Router (wbr-100)
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
dont forget to vote hope this helps
Feb 05, 2011 | NetGear WGR614 Wireless Router
Jan 22, 2011 | ASUS WL-600g Wireless Router
Feb 03, 2010 | SonicWALL PRO 1260 SonicOS Enhanced...
Jun 09, 2009 | OKI C5500n Laser Printer
May 05, 2008 | OKI B6200 Laser Printer
Nov 22, 2006 | Okilan 8100e Print Server
213 people viewed this question
