HTC HD7
Your SIM card is not properly seated, or not communicating with your carrier. First simply try and power cycle your phone. Turn it off and then leave it off for one minute. Then power it back on. If that does not solve your problem, power it back off and then make sure that your SIM card is properly seated inside your phone. Here's a YouTube video on inserting your SIM card:
HTC HD7 Inserting the SIM Card
If that still doesn't work, then you will need to contact your carrier as either the SIM card is defective, not active with your account, or there is something else going on with your account.
SOURCE: cannot transfer contacts from htc
Now I found and recommend this third party software called "GodswMobile Contacts Transfer" for Windows Mobile phone to transfer contacts to your laptop computer.
Key Features:
* Transfer both sim card contacts and mobile outlook contacts;
* Including an app for PC to view,add,delete,modify and print contacts;
* Restore contacts to any other windows mobile phones;
* Backup contacts as TXT file and CTS file;
* Backup contacts pictures and ringtones;
* Support unlimited contacts backup/restore;
* Support VGA and WVGA Screen (such as HTC Touch HD/2 and Diamond/2).
Google "GodswMobile Contacts Transfer V2.1" to free download.
OR you can go to GodswMobile Contacts Transfer V2.1 for more information.
SOURCE: what is error code:c00cee24 for the htc hd7? this
Hi, this is an issue with cookies. Go to internet explorer > Settings > Allow cookies on my phone, this should resolve.
SOURCE: my htc hd7 wont send or receive pictures, help ??
Please check with your cell phone company if MMS is active in your number.
SOURCE: my HTC HD7 will not
Hi, issues like this are related to your Sim card (network),
not your Cell Phone . In most cases, regarding the text messages,
the problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone and try sending a message from another mobile to you number,
or you can do it in vise- versa by inserting another Sim card on your mobile.
If you can't receive text messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think
it's very much important in your case, well, if you wanna try,
just check the text message settings and verify that the message
center number (which is currently in use) is the same number which
is on another phone with the same network (the other Sim should be
of the same network in your area). If it's different, make the changes
and save the settings. Also disable the "Receive Via" or similar settings..
(I can't recollect the exact settings as i don't have the same model with
me, please excuse me for this.).
If the same Sim card doesn't receive text messages using another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
Thanks for using fixya.......
SOURCE: hi i own HTC HD7
In Zune, you can reduce the amount of "Reserved" space on your phone or media player. The "reserved" for the HD7 locks in space giving you room to download material to your phone.
In Zune, select PHONE>SETTINGS>RESERVED SPACE.
From there you can allocate a percentage of the remaining memory to be "reserved" for use by the phone for downloads.
