I need the code for a sony tv and the procedur for programming my rav300 remote
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls.If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
SOURCE: Martantz SR 3000 - Are there any remote codes
Click here for Comcast Remotes Five Didgit Codes hope it works for you did for me.
SOURCE: Need a code for my Comcast Universal Remote
30176 is the code you need . Press Aux and then hold setup until Aux lights up. Enter code. If you want the remote to control the receiver all the time, press Aux and then hold setup until Aux lights up. Enter 993 then press Aux. Aux will flash, now press Cbl and Aux should light up when you use the volume.
SOURCE: verizon fios remote codes for samsung receiver
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
SOURCE: Can't set TV code on Yamaha rav293 remote
i had the same problem with the same remote but just figured it out. on the remote, to the left of the "DOCK" button, you'll see two buttons labeled "[A]" and [B] which is what you'll use as the TV source button. press the code set button, wait for it to blink two times, then press the [A] button, and press your code. VOILA! problem solved. you could also use the [B] button, but it doesn't really matter. now the tv controls work on the remote. you may have to go through all the codes for your manufacturer but eventually it should work
