Question about Soyo DYLT032D 32 in. LCD Television
How do I remove back off Soyo 32 inch tv? - Soyo DYLT032D 32 in. LCD Television
    Top Expert:
  • Soyo Master
  • 76,466 Answers
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs are given with illustrations.
Posted on Aug 04, 2014
5 Related Answers
Anonymous
SOURCE: soyo 32 inch lcd tv
Pogie14 if you still have the power supply email me at tropicalseas hotmail
Posted on Mar 03, 2009
Anonymous
  • 16 Answers
SOURCE: What screw do I remove from the back on my soyo 32" to mount ??
the screws are already removed the should be plugs little ccircles on the back to remove for a wall mount if not check the tv manual
Posted on May 12, 2009
Anonymous
SOURCE: I need a remote for a soyo 32 inch tv or a code
The RCA RCR312wv sold at Wal-Mart for about 7 bucks has 2 SOYO codes and the second one worked on my 32" SOYO
Posted on Dec 09, 2009
Chi Chu
  • 8457 Answers
SOURCE: My TV won't turn on
Ur tv have LED front panel power indicator light blinking?Or completely dead,no LED light indicator at all?Check ur power outlet source.Yes,than ur power supply board it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Apr 28, 2010
Robert Kitaji
  • 1335 Answers
SOURCE: where can I buy a replacement remote control for
The original remote is no longer available, but a substitue is. Go to
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=Soyo+MTGVTL3227AB+&uuid=12735114342500
for more information.
Please rate this solution. Thanks.
Posted on May 10, 2010
What wall mount fits a Soyo TV...MT-PRTPT3208NB
Contact the authorized dealer for Soyo. They can provide you details.
Jul 01, 2013 | Televison & Video
I need a mother board for my 32' soyo
Since you did not intimate model number of your Soyo 32 inch tv so click ShopJimmy.com and put your tv model number in search bar to locate required main board for tv.
Hope these info will help you.
Thanks.
Dec 13, 2010 | Panasonic Televison & Video
My soyo shut off and won't come turn back on
It seems like the fuse has blown on the power board inside the tv, to get at it you will have to remove the back cover, the power board should have a fuse on it somwhere have a route around and you will find it, pop it out of the fuse holder and take it to your local electrical appliance store and they should be able to get one for you, they are only cheap.
Feb 05, 2010 | Soyo DYLT032D 32 in. LCD Television
I need a remote for a soyo 32 inch tv or a code that works with a universal remote
Oct 27, 2009 | Soyo DYLT032D 32 in. LCD Television
May 12, 2009 | Soyo DYLT032D 32 in. LCD Television
I need to remove tv stand from my Soyo DYLT032D to mount on wall, Also what screws do you remove in back of TV? Thanks...
Remove Back plate screws and match up the holes on the wall mount device with the holes on the back of your television. Attach the television to mounting devise, Then mount both to the wall. Hope this helps you with your problem.
May 09, 2009 | Soyo DYLT032D 32 in. LCD Television
Cannot remove the stand on the 26 inch LCD tv (soyo)
Hello you remove the last four screws on the back of the tv located down at the bottom theres two on each side the stand will slide out...
Jan 04, 2009 | Soyo DYLT032D 32 in. LCD Television
Problems with Soyo DYLT032C 32 in. LCD Television. The TV will not turn on, I have un-plugged it and plugged it back in, in hopes it would re-set the tv. Do you have any suggestions?
Long story short:
Had the same problem with my Soyo.
Thought it was the power supply board problem that everyone else was reporting.
ordered one.  Plugged it in.  Did not work.
Inspected the Main/Logic board and found what looked like a black button that could be depressed.  It is located to the right of main processor on the board.  You can't really miss it.
With the TV plugged in, I pressed the suspect button.  The TV made a buzzing/clicking noise for a few moments and the stuck blue illuminated power button faded away.
Curious by this, I pressed the power button and low and behold the TV comes to life!
Looks like I found a "reset" button which seems to have fixed my problem.
Thanks Soyo for not bothering to mention that such a button exists.
I hope the rest of you have the same good luck.  In the event you are still in need of a power supply board, email me.  I have a spare now it seems.  ;)
Dec 10, 2008 | Soyo DYLT032C 32 in. LCD Television
Soyo DYLT032D 32 in. LCD Television Logo
74 people viewed this question
Top Soyo Televison & Video Experts
Marvin
Marvin
Vish Iyer
Vish Iyer
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
