Question about Garden
How do i change my oil on my briggs & stratton 3000 psi pressure washer. where is the oil plug located?
I mistakenly put transmission fluid in to the oil. I just purchased this product 2 weeks ago and yesterday i finally got around to putting gas and oil in it. But i accidently added a little transmission fluid in the oil and now im trying to drain the oil but i do not have a manual. can someone please help me locate the oil plug. Thanks
makdaddy1
    New Friend:
    Problem Solver:
  • 8 Answers
First of all, depending on how much tranny fluid you put in, you may not need to drain it. Transmission fluid is just oil with other additives in it. Unless you see the oil breaking down, it will probably not run badly. If you put more than a few ounces in, I would recommend changing the oil, which should be done after two hours on a new motor anyway. Some B&S engines do not have a drain plug. If there is one it will be at the base of the motor where it bolts down to the housing. Some also come with an oil drain tube, which allows you to drain the oil without getting it all over the housing. If there is not plug or tube, you can drain the oil from the motor by turning it on it's side and letting the oil drain out the fill tube. Be careful not to spill the fuel - some may leak through the fuel cap and depending on the location of the carburetor, some may leak there as well. Be sure to use 30 weight oil or oil marked as 4-stroke engine oil. Check the levels every time you use the mower to be sure that you have adequate oil and to look for signs of breakdown (thin or spotty on the dipstick) or water (milky or foamy oil) in the oil. Any doubts change the oil. $5 is a cheap price to be sure your motor is protected properly.
Posted on Aug 04, 2014
5 Related Answers
Anonymous
  • 583 Answers
SOURCE: Gas leaking from carb on Briggs and Stratton engine
`v already answerd this,are you slow? with oil in the sump you can do no damage by running the engine with abit of smoke,it will clear up very quickly. i find it hard to believe youhave done the things you claim if you dont know what a carby bowl is!! it is the receptical under the carby,take brigg`s advice and replace the gasket it is needle and seat or flappervalve
Posted on Jul 25, 2009
Anonymous
SOURCE: how to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
Posted on Apr 22, 2010
Anonymous
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Posted on Sep 26, 2010
10acT
  • 36 Answers
SOURCE: started by Craftsman 2700 PSI
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
Posted on May 09, 2011
mike butler
  • 6468 Answers
SOURCE: Briggs and Stratton 3000 psi wont start.
did you leave fuel in it for the 30days and how old was the fuel then it is only good for about 30days in small engines
Posted on Jun 09, 2012
What is the red fluid spraying from the enginee of a briggs and stration engine
It sounds like someone put transmission fluid where the oil is supposed to go. Red fluid as much that I can remember is transmission fluid not oil. Probably just grabed the wrong bottle instead of oil. You need to drain it out good and fill with the right oil. Check and see if the oil in the motor is red.
May 24, 2014 | Briggs & Stratton Prosumer 20324 Gas...
Oil type 2400psi
any hosue holdcar motor oil will work
Dec 31, 2013 | Briggs & Stratton 3000 PSI Pressure Washer
What of oil to change on the 2700 PSI Brigg & Stratton enigine? On a "Generac pressure washer" and also what type of oil and how to change the oil on the pressure washer pump.
id your engine model and consult the briggs site........
the oil in the pump is filled during assembly so it doesn't have a nice pair of fill and drain plugs
briggs :
http://www.briggsandstratton.com/eu/en/
Jun 25, 2013 | Garden
Briggs & Stratton Pressure Washer
From your description, it could be rusty water or oil. Depending on the model it could be 30w or 10w30 oil. These pumps are not supposed to need the oil changed, however ,some muppet may have changed the oil and used incorrect oil that has damaged a seal causing water to pressurize the casing and force oil out the breather or it may have been run with no water or it may have just been overfilled.
I would look online to find the correct oil and quantity for your model, check the oil in the casing to see if it is contaminated with water ( the oil will be milky brown if this is the case).
If water is present , the pump will need seals replaced ( assuming it works ok in every other way).
If the oil is clean, drain it out , replace it with the quantity and type recommended by the manufacturer and check the bungs to make sure they are sealing properly.
Dec 30, 2017 | Briggs and Stratton 020275 Elite Series...
Jun 03, 2012 | Briggs & Stratton 3000 PSI Pressure Washer
Started by Craftsman 2700 PSI , 2.3 GPM Briggs & Stratton Powered Pressure Washer for first time in 9 months. Added new oil, and gas. started but is smoking from muffler and is dripping what appears to...
Hope this helps!
May 09, 2011 | Craftsman 2700 PSI,2.3 GPM Briggs &...
Need to know where oil drain plug is on 6.75 hp Briggs & Stratton engine on 2550 psi troy bilt pressure washer!!
Aug 07, 2010 | Briggs Stratton 020273 Elite Series...
Oil
Remember when your searching for something you can't find the internet is always your best bet. You should also use a good search engine; www.bing.com is one of the best search engines I have ever used. I searched some stores that have the oil your looking for, one online store is www.amazon.com and if you have one near you and they also carry it at Sears. The grade of the oil is definitely weird, 75W90. Also if you would like to look for other stores that carry it go to Bing and type "Briggs & Stratton Pressure Washer Oil" into the search bar.
May 23, 2010 | Briggs & Stratton Briggs Stratton 2000...
How to change oil in a pressure washer
Change Pump Oil
May 21, 2009 | Briggs & Stratton Pressure Washer...
Garden Logo
229 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
