Question about Hitachi 53UDX10B 53" Rear Projection Television
How to factory reset or troubleshoot a Hitachi Ultravision Plasma 55hds69?
Screen turned black with no picture no sound. Unplugged and waited to reset without luck. Any suggestions?
5 Related Answers
Luis Amado
  • 129 Answers
SOURCE: problem in Hitachi 53UWX10BA
The convergence ic's, and related components that could'be affected need to be replaced cost to repair 250.00 2hrs job max with alignment this depending on the tech. If you need more help let me know
Posted on Jun 14, 2007
Anonymous
SOURCE: hitachi ultravision LCD
I recently had the same problem. You need to contact Hitachi (1-800-448-2244) and advise them of the issue. Hitachi will give you a local service contact who will look at your TV and advise you that the light engine needs replacement. Afterwards, you need to call Hitachi back and speak with a customer service Rep. They replaced the part (I was quoted $530) but I had to pay labor and service (($370). If your TV is 12-18 months you should be able to get them to cover both. Based on the service rep that fixed mine, he indicated he has replaced about 40 of these since late 2007. Mine was replaced last week and now I have a different issue, a bright blue pixel light. Now it's round 2 with the service department. I have not been impressed with Hitachi's customer service considering I spent $3200 on this TV 3 years ago. Hope this helps. Good Luck!
Posted on Mar 14, 2008
Anonymous
SOURCE: TV: Hitachi UltraVision no Picture.
Hitachi Ultravision power light on but on picture
Posted on Nov 19, 2009
Anonymous
SOURCE: Hitachi tv no picture or sound.
my hitachi projection tv 53uwx10b screen is black with no sound or picture when the power button is on
Posted on Dec 30, 2009
ladywinn
ladywinn
  • 5138 Answers
SOURCE: I have a Hitachi Ultravision
replace both of your STK ICs they will have part # on them STK392-110 use 150s Mats has them 1-800-628-1118
ICs are big black ICs
Posted on Sep 15, 2010
Samsung dlp hl55679w
It sounds that the light engine has the fault. Contact the authorizes service center for Samsung.
Jul 21, 2013 | Televison & Video
Intermitent black screen with sound, blue screen-no sound, normal
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck...
Sep 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Sony FD Trinitron WEGA
Here's my suggestion , unhook all the external components to the TV and leave the TV unplugged for more than a few minutes (a day/overnight). The next day plug the TV into the wall outlet (not the powerstrip) without anything hooked up to it, and turn it on. See if it comes on. Sometimes unplugging for a few minutes/hours is not long enough for it to reset itself.
Dec 28, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sharp model lc19sb25u sound and no picture screen
Part called main unit failed and require replacement. part number duntke352fm02.
Oct 08, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
2004 toshiba 65hx83 projection tv
How do you know when your light bulb has burned out? I have sound with a black screen
Aug 05, 2008 | Toshiba 55H70 55" Rear Projection...
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
LCD TV picture is green
I just called Vizio and they said to unplug the TV, then physically hold in the power button on the TV for 2 minutes.
Nov 19, 2007 | Vizio L37 Television
Our TV reset itsself to sales pitch
1) Demo mode clears by holding vol up & chan up at the same time at the set front buttons. Or try menu & power.......
2) Black box is called a text box = part of closed-caption option.
Select CC to turn text box off.........
Note:Always provide Model # , Chassis # and age......
serial # not needed / helpful..........T.
Nov 05, 2007 | Televison & Video
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Hitachi 53UDX10B 53" Rear Projection Television Logo
238 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
