Question about LG 42PX5D 42 in. Plasma HDTV
My lg 42 plasma 42PC50 won't auto scan channels I just moved it into another room it won't work help
Help
5 Related Answers
Anonymous
SOURCE: LG Plasma TV model #DU-42-PX12X
try contacting LG see if there is a backlight if there is that is most likely your problem
Posted on Aug 16, 2007
Anonymous
  • 15 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
Anonymous
  • 3 Answers
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Posted on Jan 17, 2008
Anonymous
  • 20 Answers
SOURCE: 42 LG Plasma picture distorted and flickering
replace the control module.
Posted on Mar 11, 2009
David Low
  • 458 Answers
SOURCE: 42" LG Plasma tv, no picture - black screen, but have sound.
Most a likely a problem with your Y-Sustain board which will then not drive the screen giving a black picture. The fuse on the board may be open circuit & need replaced but most likely you will need to have the sustain board replaced.
Posted on Oct 28, 2009
Tvs get reception from an antena. New LG tv won't acknowledge a dtv channel (kxtv sacramento) when scanned or manually added. Two other digital tvs utilizing the same antena scanned and added the...
The tuner on the LG TV may be right on "the hairy edge" of being able to receive that signal. Therefore the processor won't acknowledge and display it. You may want to try the LG on one of the other antenna feeds were the TVs DO display that channel. You might want to try the LG with no other sets hooked up. You may have a problem with any of the following. - staple through a wire - cracked lead-in wire or damaged coax - problem with a distribution amp/splitter.
Sep 12, 2011 | LG 42 42PT350 42 Plasma TV
My 42" plasma is constantly changing channells up. remote also not working while this is happening.
I think it may remote controllproblem.channel button or scan button were pressed. you open the remote and clean slighitly all buttons with cotton .
Thyanking you
Aug 11, 2010 | LG 42PB4D 42 in. Plasma HDTV
My tv wont pick up any channels i have a 42 inch lg tv and its connected to the household antenna but wont pick up any channels i have tried other ariels and still have the same problem?
have you switch the broadcast to Air from Cable using the remote go to this and also let it scan for channels auto...hopefully this will do the trick
Jul 26, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
I only get 12 channels. . .why?
Download the user's guide and go to page # 19 for more info on how to set up the TV to the proper input to receive all the channels.
Let me know if you need further assistance.
Jun 12, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
My flat screen lg tv has lost its channels,says its not programed...help
i was watching tv last night on my lg,and it went off and said no signal?so i went to retune and now it says not programmed i cant get my dtv channels back
Aug 20, 2009 | LG 42PG20 42 in. Plasma HDTV
LG 42 inch Plasma Picture in Picture with SKY satellite service
PIP only works off two seperate signals, eg you cannot watch 2 sky channels at a time, you can watch sky tv and then your analogue channel using PIP or freeview, you can then swap which is to be viewed as a large picture and which is to be viewed as the smaller picture or half and half.
Sep 07, 2008 | LG MZ-42PZ14 42 in. Plasma Television
LG Plasma TV
first i would try unplugging it for about 5 minutes to reset the set. after that i would need more detail as to the problem is there sparkles in the screen is it a certain portion of the set any info you can give
Jul 03, 2007 | LG 42PX4DR 42 in. Plasma TV
ONLY GET SAME 2 CHANNELS AFTER I MOVED.
Did you do a auto programming on it, also a $20.00 dollar anteanna would get you more channels also, go into the user menu and choose channel, choose either air or cable and do a auto programming on it, this will save all the channels that you can pull from using rabit ears
Apr 10, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai pdp4249g plasma monitor
Do you have any kind of anteanna? Go into the user menu and choose channel, then choose air or cable then do a auto programming this will pull in all the channels that is available and save them to the memory
Apr 10, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
LG 42PX5D 42 in. Plasma HDTV Logo
Raj Patel
