Viking Spas Comp. Pool and Spa Filter Replacement Logo
A
Anonymous Posted on Aug 03, 2014
How do I get a stuck hot tub filter out - Viking Spas Comp. Pool and Spa Filter Replacement
The Cover Guy
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 64 Answers
  • Posted on Sep 11, 2015
The Cover Guy
Expert
Level 2:
Mentor:
Answers
64
Questions
Helped
68521
Points
337
The best way to never having your hot tub filter getting stuck is.
  1. remove the hot tub filter monthly for a cleaning
  2. Only install the filter hand tight
  3. Replace your hot tub filter yearly
If your hot tub filter is stuck the best way to remove it is
  1. Turn off the hot tub power
  2. Use a strap wrench for leverage
  3. You may have to remove the water for better access
how do I get a stuck hot tub filter out - get-stuck-hot-tub-filter-out-5bvg4l51wbqaid0njx4fdwih-5-0.jpg
How to Remove Stuck Hot Tub Filter
David Spradling
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Viking Spas Master 1,448 Answers
  • Posted on Aug 25, 2014
David Spradling
Viking Spas Master
Level 3:
Renaissance:
Answers
1448
Questions
Helped
519094
Points
1901
Turn it off try grabbing with a glove on or blow air into outlets
Hot tub pump will not start back up after cleaning hot tub
When you say the pump won't start back up, do you mean the electrical side of things and there is just no power going to the pump. Or are you saying that the pump is on but not pumping water.
I am going to think you mean the pump is on but not moving water. This is common after you clean and drain your hot tub. You have what is referred to as an airlock in your hot tub line. It is easy to remove the airlock by simply opening one of the unions near the pump. This will allow the air to release and water flow to begin again.
Make sure also that you have cleaned the hot tub filters, if they are dirty and reduce water flow that could shutdown your hot tub pump as well.
If it is the electrical side of things make sure your GFCI has not tripped and maybe you just need to reset this. If it is anything further on the electrical side make sure you involve a professional.
  • open a union to release any airlocks.
  • clean your hot tub filters.
  • check to make sure your GFCI is not tripped.
Hot Tub Repair 101 What is an E6 or Error 6 Code Mean
You may have to change your hot tub filters as well and can find an assortment of filters here. The filters should be changed yearly, and cleaned monthly.
Hot Tub Filters
Jan 30, 2016 • Pool & Spa
tip
Hot Tub - Spring cleaning and Maintenance
Spring is a great time to change the water in your hot tub and clean or replace your hot tub filters. Drain and give your hot tub a good thorough cleaning to rid yourself of the winter season. Make sure that you clean your hot tub cover at the same time both the top and the underside. This will help the hot tub cover to last longer and perform better. Hot Tub Spring Cleaning Tips
on Mar 27, 2015 • Pool & Spa
3answers
Morgan hot tub
if no drain at bottom usually with hose connection on it use a sump pump or syphon make sure power is off until fully refilled
Jun 30, 2014 • Pool & Spa
2answers
Hot tub stuck in PR mode.
Are the pumps primed, the code represents that the pumps are being primed and should only stay on 2 - 5 minutes. If the pumps are not primed then you may have an air lock or dirty filters. You need to release the air or clean or replace the filters and your pumps will prime.
Mar 27, 2014 • Pool & Spa
How can I remove tannins from water
Tannins which is water that has organic material from decaying foliage can be a bit of an issue with your equipment especially the filters but for the most part is an aesthetic issue. The only way to remove the tannins is pre-filtering before you put the water in the hot tub. You can purchase a purestart pre-filter you attach to your hose when filling your hot tub. If that does not do the job there are some applications from MetalTrap that may aid you as well. If all else fails you may have to look into something more industrial like Tannin Filters Tannin Filter Systems Remove tannic acid color from well...
Hot tub doesn't heat
Steve- go to http://www.hottubworks.com/ and check out the heater trouble shooting guide. Pretty easy to narrow it down. Most common is filters being clogged (lack of flow) or heater element has burned out (easy to replace) there is a video how to do it.
3answers
Spa thermal overheating
Turn off all power to the hot tub as soon as you realize it is overheating. The spa should have an automatic shut off when the water temperature reaches about 112 degrees fahrenheit. Call your hot tub dealer or manufacturer for service options. There are a variety of conditions that could lead to the overheating of your hot tub, but may differ in various hot tub models and brands. Check the water level of the hot tub. Low water levels could be the culprit for the over heating, so you may just need to add more water to the hot tub.
Check the shut-off valves in the hot tub. If they are closed while the hot tub heater is on, it could cause the water to reach unsafe temperatures.
Clean the hot tub filter. A dirty filter could be blocking the flow of water, causing the water to sit in the hot tub and overheat.
Turn the power back on after finding the problem and talking to the hot tub dealer. The hot tub will probably not start back up until the water reaches a safe temperature
2answers
When we turn our washer elite on it gives us a error of sud?
susds error is a an fault error ....the machine has detected excessive tub pressure could be from not using "HE Soap ....if your are good but you might be using to much.... whens the last clean cycle you have ran to clean excess inner tub buildup on your washer .....
1 #drain all water out of filter sump behind lower front axcess panel make sure washer is unpluged
2# reinsert filter sump and and leave axcess panel off u make have to do this several times...
3# now check black rubber hose that goes from pump to bottom of tub remove clamp check for any obstructions in bottom of tub clean float ball of debris and reinstall and reconnect clamp to buttom of tub..
4# now pour 1 cup of vinegar directly in the tub where your clothes go and shut door( dosent mater what kind of vinegar or an affresh tablet
5# plug washer back in now lets run a clean cycle or any cycle that usues hot water ....
6# if unit suds code again this could happen a few times we need to flush out the buildup you may have to repeat steps 1-6 a couple of times....
Top Viking Spas Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Viking Spas Pool and Spa Expert? Answer questions, earn points and help others
