Computers & Internet Logo
Question about TriPro Power TRIPRO UPS 600VA/300W 12~18 USB PORT (POF600US) Power Supply
600va ups circuit diagram
Microcontroll ic not working
Vitally Alcher
  • TriPro Power Master
  • 1,645 Answers
Get new one that works
Posted on Feb 19, 2015
1helpful
UPS BE500R-PH microcontroller pic16f716
No, the PIC16F716 microcontroller does not need to be programmed before using it in a UPS. However, it is recommended that you program the microcontroller to optimize its performance for your specific UPS.
There is an available schematic diagram for the APC UPS BE500R-PH. This diagram can be found in the "APC UPS BE500R-PH User Manual".
Check it here: Back-UPS ES BE500R User guide ' Schneider Electric (apc.com)
The most efficient way to use a UPS for a home computer is to connect the UPS to the computer's power supply unit (PSU). This will ensure that the UPS provides power to the computer in the event of a power outage.
Bpl prima 18hd2 tv circuit diagram
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name or the IC number used with your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Videocon ctv cercuit diagram
Circuit diagrams are in PDF, and cannot include it here by this window. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Ups 600va luminous repairing diagram
In most cases, these ICs are pre-programmed and cannot be replaced or get it work without its firmware.
1helpful
Finding a Microcontroller for a Technics Tape Deck
I am sure there is one available or suitable sub . I wonder if technics would provide more information if you contacted them or a local electronics store.
A microcontroller may or may not be programmed for a specific purpose so, that also may be an issue if not purchesd froma source used for that device.
There is also a forum called tapeheads:
Technics RS-B49R - Tapeheads Tape, Audio and Music Forums
www.tapeheads.net >
http://www.tapeheads.net/showthread.php?t=49248
I found some links here and even a few sold for parts around 15 bucks:
Google
https://www.icom.co.jp/world/support/download/manual/disp_down.php?SWT=&ID=20010101177&GNR=Amateur&TYPE=Mobile&PDNM=IC-901A/IC-901E&INQWORDSWT=No&INQWORD=
3helpful
2answers
After a short power outage, I have clock issues.
this a problem with the clock , but the microcontroller can be defective by the power outage, see the diagram . how the microncontroller has the control for any equipment.
IN SHTE M.CONTROL BOARD CAN BE DEFECTIVE. go to the repair shop Tv FOR FIX IT. God bless you
1helpful
I already replaced the power supply now the green light comes on but there is no picture or sound and it dont responed to the remote
You must go on fromthe point you left off, trace the +B to the circuits, check the microcontroller, the sub processors, confg of the ic's can be got from manufacturer's site. Probe only if your are familiar with these sensitive circuit, have a rough idea of the LCD TV circuit. Look out for any fusible resistors to the main board replace or ceck PD across, if showing low ther could be failure of PCB ....you may be infor an expensive work... Hope this helps
2helpful
Why OSD come time to time
disolder the microcontroller IC inside the monitor. then power on the monitor without IC . short all the terminals of the IC and remove then solder the IC and power on the monitor . your problem will be absolutely solved.
Tv shuts off after 10-20 minutes
its not the problem with ur electron gun tube or with any picture ic or sound ic. Every t.v. is microcontoller switched machine.
any damage to microcontroller ic that controls the switching will lead to this kind of problem.
0.01% chance of residue EHT voltage would have affected the microcontroller.
Microcontrollers schematic diagram is being needed for my project.
What is the project? Please specify to get help. I have plenty of circuits.
Top TriPro Power Computers & Internet Experts
Marvin
Marvin
Are you a TriPro Power Computer and Internet Expert? Answer questions, earn points and help others
