Question about LGDVT418 System
Lg home theater no sound
Sound come on some time
4 Related Answers
Anonymous
SOURCE: hook up sylvania lc370ss8 LCD TV to a lg lht734 DVD home theater system
Hook a digital optic cable from the Tv's digital ouput to the Recievers digital sound in. This should fix it. You might have to switch the input of the reciever.
Posted on Apr 19, 2008
Anonymous
  • 5 Answers
SOURCE: I have and lg tv and a samsung home theater
optical audio cable from home theater to tv. can be purchased on line for a few bucks.
Posted on Jan 04, 2010
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: I need severe help. LG
Is the digital TV-related sound actually originating in the unidentified TV or would it be better to get it at, say, the Cable Box, which IS a hi-fi component, whereas TV's are amost always NOT so?
I'm pretty sure the TV manual may explain the use of its optical output.
Posted on Aug 09, 2011
SOURCE: LG DVD home theater MDD262.
audio amplifier IC damaged need to be replaced
Posted on Aug 19, 2011
Sound not coming out of center and left right speakers. only rear wireless speakers working on HT806THW LG home theater. how do i fix it?
we have a lg surround sound system with our system u can go into menu and go to audio it should show you all the speakers scroll down one at a time and make sure they werent accidently shut off it cost me forty dollars for that mistake good luck
Oct 02, 2013 | LG Audio Players & Recorders
CD will not play in surround. How do I set to have music play in surround?
Unless your CD's are DTS-encoded, you can only SIMULATE surround or employ Digital Sound Processing from stereo sources to create virtual sound spaces and effects. The manual describes it on page 13.
http://www.lg.com/us/tv-audio-video/home-theater-systems/LG-home-theater-system-LHT854.jsp
Like any spice, using sound modes is a matter of personal taste.
Check out the Knowledge Base.
http://lgknowledgebase.com/kb/index.php?CategoryID=29
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3130
Sep 21, 2011 | LG LHT854 Theater System
I need severe help. LG cant even help me. I have an LHT854 home theater system. The only time I can use surround sound, is if I watch a dvd player on it. My Tv's only "Out" is an Optical out....
Aug 08, 2011 | LG LHT854 Theater System
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
Jan 11, 2011 | LG LHB335 Theater System
Dec 21, 2009 | LG LHT854 Theater System
No sound through surround
this is because the home theater receives 5.1 channel... change it it will work...
May 17, 2009 | LG 1000W XM-Ready 5.1-Ch. Home Theater...
No sound though home theater when watching tv
There is an orange button on the remote, half way down in the middle. I belive it has orange lettering and says something like "TV-?" press that, and the sound should start to come through your speaker system. You can then use the original remote that came with your TV and turn the sound off on the TV to use just the theatre system. I noticed that if you use the TV speakers in conjunction with the theatre system, that it echo's.
Nov 23, 2008 | LG LHT854 Theater System
LG Home Theater System LHT754 no sound
All you are currently doing is getting sound OUT from the LG HT system. If you want sound from your cable or satellite, you have to run a seperate audio cable into the back of the LG system. If you are running a cable line straight into the TV you need to run an audio cable OUT of the TV so you get sound via the LG system.
Jun 17, 2008 | Audio Players & Recorders
Hook up sylvania lc370ss8 LCD TV to a lg lht734 DVD home theater system
Mar 21, 2008 | LG LHT734 System
LGDVT418 System Logo
Top LG Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
tina gallow
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
